When I run 2D code in MPI, I get the following warning (although the code still runs)
Element::Element: unknown element with 3 points
Here my element shall be a 3 point triangle, and it should not call the 3D element function to get its type…
This warning does not appear when I run in serial…
It would be easier to debug if you provide the python code
(citation Guosheng)
lol…
here is a minimal code that generate the message
I ran
mpirun -np 5 ngspy test.py
It produce four copies of
Attachment: test.py
Which versions of NGSolve are you running?
I cannot reproduce your issue with NGSolve-6.2.1902-139-gc4543a8b9 and the corresponding Netgen version.
After I updated to NGSolve-6.2.1902-139-gc4543a8
the message was gone… thanks
