is there an elegant way to apply a load to a cross section of a volume?
My volumes are mainly generated with the CSG-modeller.
Example: An elastodynamic calculation of a 3D bar. An areal force is applied to the cross section at some x coordinate. How could this be achieved without cutting the bar into two?
Thanks for your suggestions!
Hello creativeworker,
with the IfPos-CoefficientFunction you can approximate the area force by a volume force
f_vol = IfPos( x-x0+epsilon, IfPos(x0-x+epsilon, 1, 0), 0),
where x0 is the cross section x-coordinate.
However, you will need a very high polynomial degree to “resolve” the small volume area.
If you have a mesh resolving the cross section (e.g. a structured grid) this approach will work with very small epsilon and low order polynomial degree.
Otherwise I would suggest to simply “cut” the geometry into two pieces and add them as one mesh, which should not be a huge problem with CSG.
Thanks for your answer.
I do not really like the way of applying a ‘special’ volume force. So I will stick to the cutting procedure.
Is there a way of cutting a torus only once?
Hi creativeworker,
this may help. Have also a look at the documentation CSG geometry
[code]from netgen.csg import *
geo = CSGeometry()
torus = Torus( Pnt(0,0,0),Vec(0,1,0),3,1).bc(“torus”)
plane = Plane( Pnt(0,0,0), Vec(1,0,0) )
geo.Add ((torusplane)+(torus-plane))
#geo.Add (torusplane)
mesh = Mesh(geo.GenerateMesh(maxh=1))
Draw(mesh)[/code]
