Hi!
I want to solve a nonlinear nonsymmetric system of equation via a newton raphson iteration.
The problem is defined as:
fesCurl_cplx = HCurl(mesh, order = 3, nograds = True, complex = True)
fes1_cplx_iron = H1(mesh, order = 3, complex = True)
fesMixed = FESpace([fesCurl_cplx, fes1_cplx_iron])
u_A, u_Psi = fesMixed.TrialFunction()
v_A, v_Psi = fesMixed.TestFunction()
sysmat_Mixed = BilinearForm(fesMixed)
sysmat_Mixed += SymbolicBFI(
mu_invcurl(u_A)curl(v_A) +
1jomegasigmav_Au_A +
1jomegasigmav_Agrad(u_Psi)u_Psi +
1jomegasigmagrad(v_Psi)grad(u_Psi) +
1jomegasigmagrad(v_Psi)u_A)
rhs_Mixed = LinearForm(fesMixed)
rhs_Mixed += SymbolicLFI(v_Aj_coil)
rhs_Mixed.Assemble()
sol_Mixed = GridFunction(fesMixed, name = “Mixed”)
The Newton Raphson iteration works like this:
lhs = sol_Mixed.vec.CreateVector()
res = sol_Mixed.vec.CreateVector()
dsol = sol_Mixed.vec.CreateVector()
for it in range(10):
# calculate residual vector
sysmat_Mixed.Apply(sol_Mixed.vec, lhs)
res.data = rhs_Mixed.vec - lhs
# create preconditioner
pre = Preconditioner(sysmat_Mixed, "bddc") # "bddc", "multigrid"
# assemble linearized system matrix
sysmat_Mixed.AssembleLinearization(sol_Mixed.vec)
# solve linear system of equations
solvers.GMRes(A = sysmat_Mixed.mat, pre = pre.mat, b = res,
x = dsol, printrates = True, tol = 1e-10, maxsteps = 200)
# update solution
sol_Mixed.vec.data -= dsol
# check convergence
resval = sqrt(abs(InnerProduct(dsol, res)))
print ("residual = ", resval)
if resval < 1e-8:
break
For the first iteration loop this works fine but when assembling the linearization for the second time, the program crashes.
How can I fix that?
Thanks!
Nils
