Building NGSolve from scratch trouble
So “make” continues until I get this:
CMake Error at CMakeLists.txt:310 (message):
Could NOT find Pardiso
because I had -DUSE_PARDISO=ON
looking in the CMakeLists.txt file, it looks for the Pardiso library in:
libpardiso500-GNU481-X86-64.so
But I installed oneAPI MKL (which I thought had Pardiso).
After searching my entire Ubuntu, I don’t see any pardiso file with .so extension. I see some others, like .fi and .f90.
Do I need to build Pardiso?
I think this is an error in the cmake script. Perhaps -DUSE_PARDISO should not be set. I don’t think this is my error.
So, I reran cmake and set -DUSE_PARDISO=OFF. Then I was able to run make just fine. Then make install.
I could then run some of the examples, e.g. poisson.py and navierstokes.py, through python3.
If I modify poisson.py to use “pardiso” for the inverse, then it still works by running:
python3 poisson.py
However, if I run:
netgen poisson.py
then I get this:
NETGEN-6.2.2304-9-g340c34bc
Including MPI version 3.1
togl-version : 2
OCC module loaded
loading ngsolve library
NGSolve-6.2.2304-57-g3df0e63b9
Using Lapack
Running parallel using 12 thread(s)
Setup and Factorization: PARDISO returned error -3!
err = reordering problem
symmetric = 0
spd = 0
compressed = 1
inner = 0x7fcc08020b40
cluster = 0
wrote matrix to file ‘pardiso.err’, please check
File “”, line 36, in
netgen.libngpy._meshing.NgException: PardisoInverse: Setup and Factorization failed.
I don’t understand why netgen can’t use pardiso, but just running with python3 is fine.
