Creating a mesh with different (sub)-domains
Hi everyone,
I want to run a run a elasticity problem with two materials – a matrix and two spherical solids embedded in it. I need a refined mesh between the spheres as I plan to extend the code to do phase-field fracture. For getting an idea of the geometry, consider something like the attached figure:
[attachment=undefined]trialGeometry.png[/attachment] [attachment=undefined]trialGeometry.jpg[/attachment] [attachment=undefined]trialGeometry.jpg[/attachment]
The problem is that I am getting stuck at the mesh generation part itself. I am using NGSolve-6.2.1909
Consider the following snippet:
from netgen.csg import *
Do = 2.286e-3
Ho = 0.21 * Do
H1 = Do - Ho/2.
lo, bo, to = 4*Do, 2*Do, 2*Do
eps = 5.e-6 # do two refinements
left = Plane(Pnt(0,0,0), Vec(-1,0,0))
bottom = Plane(Pnt(0,0,0), Vec(0,-1,0))
back = Plane(Pnt(0,0,0), Vec(0,0,-1))
right = Plane(Pnt(lo,0,0), Vec(1,0,0))
top = Plane(Pnt(0,bo,0), Vec(0,1,0))
front = Plane(Pnt(0,0,to), Vec(0,0,1))
box = left * right * bottom * top * back * front
inleft = Plane(Pnt(H1 + Do/2., Do/2., Do/2.), Vec(-1,0,0))
inbottom = Plane(Pnt(H1 + Do/2., Do/2., Do/2.), Vec(0,-1,0))
inback = Plane(Pnt(H1 + Do/2., Do/2., Do/2.), Vec(0,0,-1))
inright = Plane(Pnt(H1 + 1.5 * Do + Ho, Do/2., Do/2.), Vec(1,0,0))
intop = Plane(Pnt(H1 + Do/2., 3.*Do/2., Do/2.), Vec(0,1,0))
infront = Plane(Pnt(H1 + Do/2., Do/2., 3.*Do/2.), Vec(0,0,1))
inbox = inleft * inright * inbottom * intop * inback * infront
spheres = [
    Sphere(Pnt(H1 + Do/2., Do, Do), Do/2.),
    Sphere(Pnt(H1 +1.5 * Do + Ho, Do, Do), Do/2.),
Spheres = spheres[0] + spheres[1]
geo = CSGeometry()
matrix = box - Spheres
innerpdms = inbox - Spheres
outerpdms = matrix - innerpdms
# onlyspheres = box * Spheres
geo.Add(outerpdms)
geo.Add(Spheres)
geo.Add(innerpdms)
outerpdms.maxh(10*eps)
innerpdms.maxh(eps/3.)
Spheres.maxh(10*eps)
msh = geo.GenerateMesh(grading=0.8)
But this simply stalls at:
importing NGSolve-6.2.1909
 Start Findpoints
 main-solids: 3
 Found points 24
 Analyze spec points
 Find edges
Would anyone have a clue as to what could be going wrong?
Thanks
Bhavesh
