error when using Integrate
I’m trying to integrate a function over a subset of the domain, but I keep getting the following error
File "/usr/local/ngsxfem/lib/python3/dist-packages/xfem/__init__.py", line 304, in Integrate_X_special_args heapsize=heapsize) netgen.libngpy._meshing.NgException: lsets need to be GridFunctions!
The function is called using
stopcritval = sqrt(Integrate(levelset_domain=lset_haspos, cf=f, mesh=mesh))
where f is a GridFunction, and lset_haspos is defined by:
lsetp1 = GridFunction(H1(mesh,order=1)) InterpolateToP1(lset,lsetp1) lset_haspos = { "levelset" : lsetp1, "domain_type" : HASPOS, "subdivlvl" : 0}
As far as I can tell, all arguments are of the right type, so I have no idea why I’m being told that “lsets need to be GridFunctions”. Does anyone know what I’m doing wrong?
thanks,
Julien
Dear Julien,
HASPOS is not a DOMAIN_TYPE (but a COMBINED_DOMAIN_TYPE). This leads to the fact that the dictionary lset_haspos does not fit the interface. If you want to integrate on the part where the level set function is positive, simply use “domain_type”: POS.
I have to admit that the Exception is not really helpful and rather misleading. I will have a look at that.
Hi Christoph,
Switching to POS did the trick.
thanks for the fast reply,
Julien
