I am trying to solve Poisson equation on a contraction step problem. I get an error to set dirichlet boundary condition at different boundaries.
Here is the part of the code:
import netgen.gui
from netgen.meshing import Element0D, Element1D, Element2D, MeshPoint, FaceDescriptor, Mesh
from netgen.csg import Pnt
ngsglobals.msg_level =2
%% Geometry generation (points definition)
geo = geom2d.SplineGeometry()
p1 = geo.AppendPoint (0,0)
p2 = geo.AppendPoint (3,0)
p3 = geo.AppendPoint (3,0.1)
p4 = geo.AppendPoint (2,0.1)
p5 = geo.AppendPoint (2,1)
p6 = geo.AppendPoint (0,1)
(Boundaries definition)
geo.Append ([“line”, p1, p2],bc=1) # bottom
geo.Append ([“line”, p2, p3],bc=2) # outlet
geo.Append ([“line”, p3, p4],bc=3) # horizontal
geo.Append ([“line”, p4, p5],bc=4) # vertical
geo.Append ([“line”, p5, p6],bc=5) # top
geo.Append ([“line”, p6, p1],bc=6) # Inlet
fes = H1(mesh, order=2, dirichlet=[1,2])
The error happens for the last line:
TypeError: init(): incompatible constructor arguments. The following argument types are supported:
1. ngsolve.comp.H1(mesh: ngsolve.comp.Mesh, **kwargs)
Invoked with: <netgen.libngpy._meshing.Mesh object at 0x000002303900E530>; kwargs: order=2, dirichlet=[1, 2]
Thanks in advance
