How to calculate the error on the skeleton of mesh
#mesh
geo.AddRectangle( (0, 0), (1, 1))
mesh = Mesh( geo.GenerateMesh(maxh=1/16))
velocity = CoefficientFunction(UN.components[0:2])
err_u = sqrt (Integrate ( (velocity-exact_u)*(velocity-exact_u), mesh))
Now,I want to calculate the error on the skeleton of mesh, namely ,the L^2 error of mass flux jump [v_h] \cdot n
#tex
[tex] \sum_{F \in \mathcal{F}{h}} \frac{1}{h{F}}\left| \llbracket {v}{h} \rrbracket \cdot {n}{F}|{L^{2}(F)}^{2}[/tex]
#\mathcal{F}
{h} stand for all facets of mesh
Hi Yongbin,
The simplest way to compute this quantity is by defining a bilinear form a so that a(u,u) coincides with your (sum of) integral(s). Then you Apply the bilinear form to your discrete solution u and take the inner product of the result with u again.
Hi,Christoph,
Thank you very much for your reply. Sorry,I may not fully understand what you mean. This is my code for Stokes . I don’t know how to calculate in my code. In addition,I also wonder, is there other way to calculate?
Thank you again!
Yongbin
Hi Yongbin,
Here is the code fitting your script. I use hybrid dg jumps here as you use a hybrid DG formulation:
a_jumps = BilinearForm(X)
a_jumps += (ubar-uu)*(vbar-vv) * dx(element_boundary = True)
AUNvec = UN.vec.CreateVector()
a_jumps.Apply(UN.vec,AUNvec)
jump_norm = sqrt(InnerProduct(AUNvec,UN.vec))
print(jump_norm)
Alternatively, if you are interested in the standard DG jumps the code looks as follows:
uuOther = CoefficientFunction((ux.Other(), uy.Other()))
vvOther = CoefficientFunction((vx.Other(), vy.Other()))
a_jumps += (uuOther-uu)*(vvOther-vv) * dx(skeleton = True)
print(jump_norm)
Alternatives? I think this is the most straight-forward way to do it. As of now there is no “Integrate” equivalent that would allow you to integrate the skeleton-terms directly. However, I think the above approach is also very natural.
I have successfully solved this problem according to your reply, thank you very much for your reply!
Yongbin Han
Hi Yongbin,
often one needs these terms in residual-type error estimators. Then you need them element by element.
This is now also supported:
    elerr = Integrate ( h*(n*(lam*grad(gfu)-(lam*grad(gfu)).Other()))**2*dx(element_boundary=True), mesh, element_wise=True)
full example is attached.
You can integrate elementwise, on every element boundary, and use also values from the neighbouring elements.
This is a quite new feature and needs some more testing. Faces at the domain boundary are skipped, at the moment.
Attachment: residual_ee.py
Dear Professor !
Thank you very much for your advice and guidance. Let me have a further understanding of this problem.
Yongbin Han
