I’m having trouble using the hp-refinement of ngsolve with the attached code. While the mesh generated looks reasonable, the error increases from 5.708879679178683e-13 to 0.015308713648027968 when I do one mesh.RefineHP step.
The console output also says something about “used dof inconsistency”. Am I doing something wrong or is there some bug somewhere?
if you have two edges with hp-refinement which are connected, you also have to add a hpref at the crosspoint. In your case at all points of the geometry.
