So I have this space:
Bdy_Space = FacetFESpace(mesh, order=0, dim=2, definedon=“”, definedonbound=“Gamma”)
Note: this space has two components, or at least it should.
I then do this:
zero_vec = CoefficientFunction((0.0, 0.0))
And when I try this:
gf = GridFunction(Bdy_Space)
gf.Set(zero_vec, dual=True)
I get this error:
netgen.libngpy._meshing.NgException: Error in SetValues: gridfunction-dim = 1, but coefficient-dim = 2
It seems to think the grid function has only one component. But the Bdy_Space was specified with 2. What is the deal?
Did this get fixed? I noticed Joachim made a commit related to this.
Hey,
yes, it should be fixed now and is available in the latest nightly build.
Ok, so I guess this doesn’t update the conda ngsolve package. So I should switch to compiling everything.
So I tried using the PIP installer with the --pre flag, which supposedly gives the latest release. Everything installed properly, but I still get the error noted above about the dimension of the space.
here is a standalone code to reproduce the issue:
import netgen.gui
#from netgen.geom2d import unit_square
make the mesh
geo.AddRectangle( (0,0), (1,1), bc = “Gamma”)
Om_mesh = Mesh(geo.GenerateMesh(maxh=1.0))
for r in range(3):
Om_mesh.Refine()
Draw(Om_mesh)
print(Om_mesh.GetBoundaries())
bdy space
Bdy_Space = FacetFESpace(Om_mesh, order=0, dim=2, definedon=“”, definedonbound=“Gamma”)
print(" ")
num_Gm_dofs = np.sum(Bdy_Space.FreeDofs())
print("number of FreeDofs for Bdy_Space: ", num_Gm_dofs)
print("Bdy_Space FreeDof mask: ")
print(Bdy_Space.FreeDofs())
this does not work
#gf.Set((x*y,y), dual=True)
(this “works”, but shouldn’t)
gf.Set(x*y, dual=True)
print(gf)
#help(gf)
uu = Bdy_Space.TrialFunction()
IP = InnerProduct(gf,uu)
input(“Press Enter to finish…”)
the line: gf.Set((x*y,y), dual=True)
is what I need to work, but it doesn’t.
For the latest nightly build (self-compiled)
gf.Set((xy,y), dual=True)
works, whereas
gf.Set(xy, dual=True)
does not work as expected.
You can try using
Bdy_Space = VectorFacetFESpace(Om_mesh, order=0, definedon=“”, definedonbound=“Gamma”)
instead of
VectorFacetFESpace has automatically the dimension of the mesh, i.e. 2 in your example.
Thank you for this. I think the reason it did not work is because I didn’t have the latest build. The other forum thread told me what to do.
Note: I need to use the “dim” argument, because in 3-D, I need to set dim=5 (not the spatial dimension).
