Local error estimation on the element boundary
I am trying to apply the Dorfler marking criterion for an adaptive mesh, which uses the following eta:
Here, the second term R_e is proportional to the jump in the normal derivative of u_h across the edge e shared by this element and a neighboring element. And I am having trouble calculating it. First, as I checked the example codes for mesh adaptivity, I found only
elerr = Integrate (err, mesh, VOL, element_wise=True)
which is an element-wise integration on the whole element.
I have two questions:
  1. Is there any way to do element-wise integration on the boundary of each element? I saw someone calculating similar things using dx(element_boundary=True), what is the difference between this and ds(element_boundary=True)?
  2. When we generate the normal vectors by n = specialcf.normal(2)
    How is its direction decided when I evaluate it on an interior edge?
Thanks in advance!
