I am now starting to play with MPI in ngsolve and got a couple of questions to ask:
(1) For my installation, I am asking ngsolve to download and build for me metis, mumps, and hypre, while it succeed in buliding all the packages, I can not get mumps working. In the final linking phase, my libngla.so has some undefined references…
…/linalg/libngla.so: undefined reference to blacs_gridinfo_' ../linalg/libngla.so: undefined reference to pzpotrf_’
So, I my working installation, I have to turn off mumps. This is always the most painful part due to my limited c++ experience… Do you see an immediate fix for this? I can provide more details about my build if you want…
(2) In https://ngsolve.org/docu/latest/how_to/howto_parallel.html, it says taskmanager allows for hybrid parallelization. I am assuming it is MPI+OPENMP, so how to do this hybrid parallization? I tried to run
mpirun -n 4 ngspy mpi_poisson.py
with SetNumThreads(8) in the code, but it didn’t work…
(3) Again in https://ngsolve.org/docu/latest/how_to/howto_parallel.html, it says mpi does not support periodic boundary yet :<
But in the git repository, there is a quite recent commit on mpi+periodic… are you recently working on solving this issue?
I think the problem here is the loading of the BLACS/SCALapack libraries.
You can:
[ul]
[li]Use “ngspy” instead of python3[/li]
[li]Set these libraries in the LD_PRELOAD_PATH (have a look at the “ngspy”-file in the NGSolve bin-directory)[/li]
[li]In your python scripts, before importing ngsolve:
from ctypes import CDLL, RTLD_GLOBAL
for lib in THE_LIBRARIES_YOU_NEED:
CDLL(lib, RTLD_GLOBAL)
[/li]
[/ul]
MPI & C++11 threads. It should work like this:
ngsglobals.numthreads=X
Assembling/Applying of BLFs will be hybrid parallel, but most of the solvers/preconditioners will still be MPI-only.
It should work. Keep in mind that your mesh must contain Surface- and BBND- Elements. (This is only an issue with manually generated meshes). Please contact me if you run into any problems with this.
Here is the details of my build, maybe you can help me find the bug:
(1) I have a local gcc-8.1, python3, and mpich installed
(2) I am using intel mkl library to locate Lapack/Blast
do-configure.txt contains my cmake details
c.txt is the output of running “./do-configure”,
m.txt is the output of running “make VERBOSE=1”, which produce the error message at final linking stage (line 4744–4756)
But then I encountered an issue with MUMPS, in the demo code mpi_poisson.py, I refined twice the mesh with ngmesh.Refine() to make the problem bigger, then mumps solver failed to factorize the matrix, exit with a segmentation fault… hyper and masterinverse are working fine…
Is it a bug, or is there still something wrong with my installation?
I was able to reproduce the issue, but was unable to find a bug in NGSolve that caused it.
I just tried it with the newest MUMPS release (5.2.0) and it works without issues now.
I then looked in the release notes of MUMPS and found:
“Workaround a segfault at beg. of facto due to a gfortran-8 bug”
Might this also be the issue you are having?
You can update the MUMPS version that is built with NGSolve in the file
NGSOLVE-SRC/cmake/external_projects/mumps.cmake
Replace the URL/URL_MD5 lines with the link to the newest Version.
URL “http://mumps.enseeiht.fr/MUMPS_5.2.0.tar.gz”
URL_MD5 cd6d06f27ce2689eb0436e41fcc9caed
