Power P integral variational formulation
Hello, I have a problem formulation in this (simplified) form :
Where u_primal is a known vector, and u_dual v_dual are test and trial functions.
In order to solve this problem on NGSolve, I use the Lax-Milgram theorem to change the weak formulation.
The aim is now to to solve this problem.
The way I did this is :
def run_dual(gfRho,gfu_primal):
    gfu_dual = GridFunction(V2)
    # Known value of the integral since u_primal is known
    first_integral=([val**(1/exp - 1) for val in Integrate(gfRho * stress(gfu_primal) ,mesh, element_wise=True)])
    # Lax Milgram formulation
    aNRJ=BilinearForm(V2, symmetric=True,check_unused=False)
    #  Right part of the formula (with epsilon(u) : epsilon(v))
    aNRJ+=SymbolicEnergy((1/2)*(InnerProduct((Sym(Grad(v_dual))), Sym(Grad(v_dual)))), definedon=mesh.Materials("active"))
    #  Left part of the formula
    aNRJ+=SymbolicEnergy(-1 *  first_integral   * stress(v_dual)  , definedon=mesh.Materials("active"))
    # Solver
    solveStateEquationEnergy(gfu_dual,4,aNRJ,V2, dampfactor=0.1,maxit=40,maxerr=0.5e-8)
    return gfu_dual
My question is the following : The way I implemented the first integrale (at the 1/exp - 1 power) is for sure wrong. I don’t have any clue on how to achieve it and write the exact same way my formula. Can you please help me to achieve implementing this formula ?
I am sure that the first part (left part of formula) is correct, the error is how I wrote the left part of the formula.
Thanks a lot ! :slight_smile:
Your first term does not contain any test function? Or is there a typo and the u_dual should be a v_dual?
Why do you compute the integral element wise? From your formulation it seems you should use Integrate(rho * stress(gfuprimal), mesh)
Thank you for your replying this quick !
As I said, using Lax Milgram theorem, i only need Trial function :
Also, for the Integrate, I used both elementwise=True and False
Yes, for all v. The testfunction v should be in each expression.
My first guess is you want a linearform like this for your left side expression:
par = Integral(theta * sigma(gfu), mesh)**(1/p-1)
f += par * sigma(v_dual) * dx
but without further context it is hard to tell…
