saving the mesh in .vol format
i am using the following script for converting the mesh from gmesh to netgen .vol but I would like to save the mesh also through my script.
from netgen.meshing import *
import the Gmsh file to a Netgen mesh object
mesh = ReadGmsh(“coarse_test”)
wrap it into an NGSolve mesh
mesh = Mesh(mesh)
print (“num vol elements:”, mesh.GetNE(VOL))
print (“num bnd elements:”, mesh.GetNE(BND)).
When I am using mesh.Save (“newmesh.vol”), its throwing back the following error:
File “testgmsh.py”, line 18, in
AttributeError: ‘ngsolve.comp.Mesh’ object has no attribute ‘Save’.
So could someone help me with saving the mesh after its converted using the script
There is a difference between the NGSolve mesh (used for FE computations) and the Netgen mesh (from the mesher). When you do
mesh = Mesh(mesh)
you convert the mesh to a NGSolve mesh, but only the Netgen mesh has the Save function. You can either call Save before this conversion or you can get the Netgen mesh from the NGSolve one by calling
mesh.ngmesh.Save("newmesh.vol")
