Set number of V-cycles in multigrid preconditioner
Hey!
I am trying to use your multigrid preconditioner and set its number of V-cycles. When taking the following page as a starting point:
https://ngsolve.org/docu/nightly/i-tutorials/unit-2.1.1-preconditioners/preconditioner.html
I see how I can build a multigrid preconditioner object.
In this file in the C++ code, I can see how this object is constructed:
Moreover, it shows me the existence of a MultiGridPreconditioner object in Python, which is the MGPreconditioner class in C++. This class has a ngmg::MultigridPreconditioner pointer which drives the multigrid, and this class has a method “SetCycle” that sounds to me like the right method:
In the constructor of the MGPreconditioner class, it calls this method,
which indicates to me that when I create the preconditioner from Python using MultiGridPreconditioner(A, cycle=N), it should set the cycles. However, no matter how I change the N, the preconditioner does not seem to improve. See the following code. Am I missing something? Is perhaps cycle not the number of V-cycles?
import netgen.gui
def SolveProblem(h=0.5,
                 p=1,
                 levels=1,
                 condense=False,
                 precond="local",
                 cycle=5):
    Solve Poisson problem on l refinement levels.
        h: coarse mesh size
        p: polynomial degree
        l: number of refinement levels
        condense: if true, perform static condensations
        precond: name of a built-in preconditioner
        cycle: (non-working) number of cycles of the multigrid preconditioner
    OUTPUT:
        List of tuples of ndofs and iterations
    mesh = Mesh(unit_square.GenerateMesh(maxh=h))
    fes = H1(mesh, order=p, dirichlet="bottom|left")
    u, v = fes.TnT()
    a = BilinearForm(fes, eliminate_internal=condense)
    a += grad(u) * grad(v) * dx
    f += v * dx
    Draw(gfu)
    if precond == 'multigrid':
        c = MultiGridPreconditioner(a, cycle=5)
        c = Preconditioner(a, precond)
    steps = []
    for l in range(levels):
        if l > 0:
        fes.Update()
        gfu.Update()
            # Conjugate gradient solver
            inv = CGSolver(a.mat, c.mat, maxsteps=1000)
            # Solve steps depend on condense
            if condense:
                f.vec.data += a.harmonic_extension_trans * f.vec
            if condense:
                gfu.vec.data += a.harmonic_extension * gfu.vec
                gfu.vec.data += a.inner_solve * f.vec
        steps.append((fes.ndof, inv.GetSteps()))
        if fes.ndof < 15000:
            Redraw()
    return steps
print([
    SolveProblem(levels=5, precond="multigrid"),
    SolveProblem(levels=5, precond="multigrid", cycle=5)
