I am switching SymbolicBFIs to dx/ds syntax.
But, I can not specify user defined int-rules (e.g. mass lumping) in dx formulation.
Is there a fix?
Guosheng
Is there a fix?
Guosheng
Hi Guosheng,
Adding integration rules with the dx syntax was missing, I just added it.
You can now provide an integration rule for every element shape like that:
a += u*v*dx(intrules={TRIG:ir})
Actually, it is also possible with the current code by this workaround:
a.integrators[0].SetIntegrationRule(TRIG,ir)
By adding a dx-integral to a BilinearForm, it is internally converted to a SymbolicBFI.
best, Joachim
Attachment: test_intrule.py
