I’m producing my final publication plots at the moment like that:
- Export a vtk file using
vtk = VTKOutput(ma = self.mesh,coefs=coefs,names=names, filename = directory + filename, subdivision=0, legacy=True) vtk.Do()
- Import that .vtk file again using the vtk library
reader = vtk.vtkUnstructuredGridReader()
reader.SetFileName(filename)
reader.ReadAllVectorsOn()
reader.Update()
data = reader.GetOutput()
# a 2D matrix of size npoints x 3
coordinates = np.array(data.GetPoints().GetData())
# print(coordinates.shape)
# print(coordinates[0])
connectivity = np.array(data.GetCells().GetData()).reshape(-1,4)
# print(connectivity.shape)
# print(connectivity[0])
weights = data.GetPointData().GetArray("vec")
npweights = np.array(weights)
- Do the plotting using matplotlib
fig = plt.figure()
fig.set_size_inches(10.5, 10.5)
ax=fig.add_axes([0,0,1,1])
ax.set_title(label)
tri = mtri.Triangulation(x,y,tri)
ax.triplot(tri, alpha = 0.1)
ax.scatter(x,y,s=0.5, color='black')
tpc = ax.tripcolor(tri, w, alpha=0.5)
fig.colorbar(tpc)
ax.set_aspect('equal')
This method works fine, but seems not super elegant. Are there any suggestions to improve it? Especially, how could I get the tri = mtri.Triangulation(x,y,tri)
and the w
directly from ngsolve fes and Coefficient- / GridFunction?
Thanks!
