https://ngsolve.org/media/kunena/attachments/1658/meshing_bug.PNG
https://ngsolve.org/media/kunena/attachments/1658/FFFP_mesh.py
https://ngsolve.org/media/kunena/attachments/1658/elektrode_single.stp
https://ngsolve.org/media/kunena/attachments/1658/meshing_bug.PNGHi!
I created geometry and meshed it using Ngsolve ngmesh = occgeo.GenerateMesh(meshsize.very_fine)
As you can see from the attached images, the edges at the bottom were meshed differently and wrongly. In my opinion, the meshing should be performed symmetrically at the bottom, which is not the case.
I was wondering what is the reason and how I can handle this problem. I attached the code to easily reproduce the result.
I ran Netgen on Window, The Output in the command line is given below:
NETGEN-6.2.2105
togl-version : 2
OCC module loaded
loading ngsolve library
NGSolve-6.2.2105
Using Lapack
Running parallel using 4 thread(s)
importing NGSolve-6.2.2105
(should) load python file 'FFFP_mesh.py'
Number of colours in STEP File: 0
Highest entry in topology hierarchy:
3 solid(s)
Preparing visualization (deflection = 0.01) ... done
Face 1 / 22 (parameter space projection)
Face 2 / 22 (parameter space projection)
Face 3 / 22 (parameter space projection)
Face 4 / 22 (parameter space projection)
Face 5 / 22 (parameter space projection)
Face 6 / 22 (parameter space projection)
Face 7 / 22 (parameter space projection)
Face 8 / 22 (parameter space projection)
Face 9 / 22 (parameter space projection)
Face 10 / 22 (parameter space projection)
Face 11 / 22 (parameter space projection)
Face 12 / 22 (parameter space projection)
Face 13 / 22 (parameter space projection)
Face 14 / 22 (parameter space projection)
Face 15 / 22 (parameter space projection)
Face 16 / 22 (parameter space projection)
Face 17 / 22 (parameter space projection)
Face 18 / 22 (parameter space projection)
Face 19 / 22 (parameter space projection)
Face 20 / 22 (parameter space projection)
Face 21 / 22 (parameter space projection)
Face 22 / 22 (parameter space projection)
Delaunay meshing
Delaunay meshing
Delaunay meshing
start tetmeshing
Success !
start tetmeshing
Success !
Remove Illegal Elements
Volume Optimization
Curve elements, order = 2
('plastics', 'wall', 'medium')
('bc_1', 'bc_2', 'bc_3', 'bc_4', 'Electrode_1', 'Electrode_1', 'Electrode_1', 'Electrode_1', 'Electrode_0', 'Electrode_0', 'Electrode_2', 'Electrode_2', 'Electrode_2', 'Electrode_2', 'Electrode_1', 'Electrode_0', 'Electrode_2', 'bc_18', 'bc_19', 'bc_20', 'bc_21', 'bc_22')
Finished executing FFFP_mesh.py
