I have a surface mesh which has a hole. I looked around, but found no info on flags or special commands needed to process such meshes. To generate the volume mesh, I run the script:
import netgen.meshing as meshing
mesh = meshing.Mesh()
mesh.Load(“srfmsh_in_2.vol”)
mesh.GenerateVolumeMesh(meshing.MeshingParameters())
mesh.Save(“out_in.vol”)
The mesh (srfmsh_in_2.vol) seems clean - netgen doesn’t complain, and it is not a huge mesh (~63K faces). After ~1/2 hour, several notifications “start tetmeshing”, and many ‘Smooth Mesh’ steps noted in the gui pane . . . netgen dies. I include the output below.
Any pointers?
Regards,
Tim
NETGEN-6.2-dev
togl-version : 2
OCC module loaded
loading ngsolve library
NGSolve-6.2.1707-81-g909f6c6e
Using Lapack
Running parallel using 4 thread(s)
importing NGSolve-6.2.1707-81-g909f6c6e
(should) load python file ‘script_2.py’
generate vol mesh
Meshing subdomain 1 of 1
Delaunay meshing
start tetmeshing
start tetmeshing
start tetmeshing
start tetmeshing
start tetmeshing
start tetmeshing
start tetmeshing
start tetmeshing
start tetmeshing
start tetmeshing
File “”, line 5, in
RuntimeError: Caught an unknown exception!
Finished executing script_2.py
