1d pml
I am simulating 1D scalar wave equation in NGSolve with an incident plane wave. I have to use absorbing boundary conditions for which I take help of PML. I have used PML in 2D simulations before and thought 1D implementation would be simpler but I cannot make it work. Here is the line where I implement cartesian PML.
mesh.SetPML(pml.Cartesian(maxs =10, mins = 32.5, alpha=1j), ‘m6’),
where domain of interest is [10, 32.5], material outside this domain is labelled ‘m6’ where PML is to implemented.
Let me know of any mistakes. Appreciate your help.
P.S. Solution
Can you post the example?
Yes. Here is the 1D wave propagation problem that I am trying to solve. Thank you.
import ngsolve as ngs
from netgen.meshing import *
import scipy.io
#%% Geometry
nnodes = 10
part = [-20, -10, 0, 0.5, 1, 11, 21]
n = []
for i in range(len(part) - 1):
    n.append(nnodes)
unit_cell = Mesh(dim = 1)
diff = 0
nodes = np.empty(0)
for i in range(len(n)):
    a = np.linspace(part[i] + diff, part[i + 1], n[i])
    nodes = np.append(nodes, a)
    diff = np.abs(nodes[len(nodes) - 1] - nodes[len(nodes) - 2])
# nodes = np.delete(nodes, 0)
pnums = []
for i in range(sum(n)):
    pnums.append(unit_cell.Add(MeshPoint(Pnt(nodes[i], 0, 0))))
idx1 = unit_cell.AddRegion("pml", dim=1)
idx2 = unit_cell.AddRegion("hom", dim=1)
idx3 = unit_cell.AddRegion("rt1", dim=1)
idx4 = unit_cell.AddRegion("rt2", dim=1)
for i in range(len(nodes)-1):
    if nodes[i] <= part[1]:
        unit_cell.Add (Element1D([pnums[i], pnums[i+1]], index = idx1))
    elif nodes[i] > part[1] and nodes[i] <= part[2]:
        unit_cell.Add (Element1D([pnums[i], pnums[i+1]], index = idx2))
    elif nodes[i] > part[2] and nodes[i] <= part[3]:
        unit_cell.Add (Element1D([pnums[i], pnums[i+1]], index = idx3))
    elif nodes[i] > part[3] and nodes[i] <= part[4]:
        unit_cell.Add (Element1D([pnums[i], pnums[i+1]], index = idx4))
    elif nodes[i] > part[4] and nodes[i] <= part[5]:
    elif nodes[i] > part[5] and nodes[i] <= part[6]:
id5 = unit_cell.AddRegion("l", dim=0)
id6 = unit_cell.AddRegion("r", dim=0)
unit_cell.Add (Element0D(pnums[0] , index=id5))
unit_cell.Add (Element0D(pnums[-1], index=id6))
#%% Meshing
mesh = ngs.Mesh(unit_cell)
mesh.SetPML(pml.Cartesian(mins = -10, alpha=1j, maxs = 11), 'pml')
#%% Materials
rhd = {'pml' : 1, 'hom' : 1, 'rt1' : 1, 'rt2' : 1}
mud = {'pml' : 2, 'hom' : 2, 'rt1' : 2, 'rt2' : 2}
rho = CoefficientFunction([rhd[mat] for mat in mesh.GetMaterials()])
mu  = CoefficientFunction([mud[mat] for mat in mesh.GetMaterials()])
#%% Solution
omega = 2
fes = H1(mesh, order=3, complex=True)
u = fes.TrialFunction()
v = fes.TestFunction()
b = (10**2 / np.pi) * exp(-50**2*((x+7)**2))
a += mu*grad(u)*grad(v)*dx - omega**2*rho*u*v*dx
f += b*v*dx # + t*v*ds("dir_neu")
gfu.vec.data += a.mat.Inverse(freedofs=fes.FreeDofs()) * f.vec
1D_wav_prop.py (2.7 KB)
the solution I get from you script does not look that wrong:
I am not sure if you wanted your point distribution like that (going backwards from 1 to 0.5):
here is the notebook I was running from your code:
PML1d.ipynb (48.9 KB)
Thank you Joachim for your response. Can you explain a bit more on what you mean by point distribution going backwards?
the list n is not sorted
Hi Joachim,
I am still not convinced that pml I implemented works. For example, why do I have sharp kink at the right boundary in the imaginary part of the field u where the pml starts? What am I missing. Thank you.
P.S. I have updated the code since my last post so that now the list n is sorted. I am attaching the code for your reference
1dpml.py (2.6 KB)
the 1D elements have point enumeration ‘right point’, ‘left point’, like:
unit_cell.Add (Element1D([pnums[i+1], pnums[i]], index = idx1))
