Hello everyone,
I wrote a code in order to calculate eigenvalue for a 3D beam using NGSolve. I got inspired by Sebastian Hirnschall, Christoph Leonhartsberger and Rafael Dorigo’s work “Computing igenfrequencies using Finite Element Methods”.
I have a problem which is having negative values in stuiffness matrix when computing “scipy.linalg.eigh”.
Did any of you have had this problem please ? Could you please help me solve the problem I appreciate in advance.
Here is the code:
from netgen.csg import *
import math
import scipy.linalg
from numpy import *
from netgen.NgOCC import *
def getF(l,shift=0):
return (sqrt(abs(l - shift)) / (2 * math.pi))
maxh1 = 10
E, nu, rho = 210000, 0.3, 7810e-9
mu = E / 2 / (1+nu)
lam = E * nu / ((1+nu)*(1-2*nu))
maxNumIterations = 50
eps = 1e-6
geometryPath = "Geometrie.stp"
geometry=OCCGeometry(geometryPath)
mesh = Mesh(geometry.GenerateMesh(maxh=maxh1)).Curve(3)
fes = VectorH1(mesh, order=3, dirichlet="Face3")
u = fes.TrialFunction()
v = fes.TestFunction()
a = BilinearForm(2 * mu * InnerProduct(0.5 * (grad(u) + grad(u).trans), 0.5 * (grad(v) + grad(v).trans)) * dx + lam * div(u) * div(v) * dx)
pre = Preconditioner(a, "multigrid", inverse="sparsecholesky")
m = BilinearForm(rho * u * v * dx)
m.Assemble()
num = 10
u = GridFunction(fes, multidim=num)
uvecs = MultiVector(u.vec, num)
vecs = MultiVector(u.vec, 2 * num)
for v in vecs[0:num]:
v.SetRandom()
uvecs[:] = pre * vecs[0:num]
lams = Vector(num * [1])
res = [1] * (maxNumIterations)
numIterations = 0
while True:
numIterations += 1
vecs[0:num] = a.mat * uvecs[0:num] - (m.mat * uvecs[0:num]).Scale(lams)
vecs[num:2 * num] = pre * vecs[0:num]
s = InnerProduct(vecs[num], vecs[0])
for j in range(1, num):
tmp = InnerProduct(vecs[num + j], vecs[j])
if s < tmp:
s = tmp
res[numIterations - 1] = s
vecs[0:num] = uvecs[0:num]
vecs.Orthogonalize()
print(vecs[0])
asmall = InnerProduct(vecs, a.mat * vecs)
msmall = InnerProduct(vecs, m.mat * vecs)
print(asmall)
ev, evec = scipy.linalg.eigh(a=asmall, b=msmall)
lams = Vector(ev[0:num])
print(numIterations, ":", [getF(l, 0) for l in lams])
print("res:", res[numIterations-1], "\n")
if (numIterations==1):
tmp = MultiVector(u.vec, 2 * num)
tmp[0:2*num] = vecs
vecs = MultiVector(u.vec, 3 * num)
vecs[0:2*num] = tmp[0:2 * num]
uvecs[0:num] = vecs * Matrix(evec[:, 0:num])
vecs[2 * num:3 * num] = vecs[0:num]
if (abs(res[numIterations-1]) < eps or numIterations >= maxNumIterations):
break
for j in range(num):
u.vecs[j][:] = 0.0
u.vecs[j].data += uvecs[j]
Draw(u)
I think you run into numerical instabilities of scipy eigh.
What works for me (I run then later down in line 76 in some non matching matrix sizes) is orthogonalizing the vecs wrt the mass matrix:
I have a problem vizualising the eigenmodes using NETGEN. All I get is a grey drawing of the mesh eventhough the frequencies are correct and the script works fine.
go to visual menu
select clipping plane sol: Vector Funtion
then go clipping menu
select enable clipping
and then with the multidim component selector you can select the eigenfunctions to the corresponding eigenvalue
