About the facet integral in the DG methods for solving the Stokes equation
To solve the Stokes equation, we use the DG methods. And the following formula is an important facet integral:
[tex]\sum_{F\in\mathcal F_h}\oint_F\left{\nabla\bm{u}\right}\bm{n}_F\cdot \left[\bm{v}\right]\mathrm{d}F.[/tex]
If coding in the NGSolve, I try this:
def outer(W,n):
    return CoefficientFunction((W[0]*n[0], W[0]*n[1], W[1]*n[0], W[1]*n[1]), dims=(2,2))
def grad(a,b):
    return CoefficientFunction((a.Diff(x), b.Diff(x), a.Diff(y), b.Diff(y)), dims=(2,2))
fes = L2(mesh, order=order_p, dim=2, dgjumps=True)
U, V = fes.TnT()
ux, uy = U
vx, vy = V
ux_other, uy_other = U.Other()
vx_other, vy_other = V.Other()
U_vec = CoefficientFunction((ux, uy))
U_Other = CoefficientFunction((ux_other, uy_other))
V_vec = CoefficientFunction((vx, vy))
V_Other = CoefficientFunction((vx_other, vy_other))
jump_U = U_vec - U_Other
jump_V = V_vec - V_Other
mean_gradU = 0.5*(grad(ux, uy) + grad(ux_other, uy_other))
mean_gradV = 0.5*(grad(vx, vy) + grad(vx_other, vy_other))
a += SymbolicBFI( InnerProduct( outer(jump_V, n), mean_gradU ),\
                               VOL, skeleton=True )
a += SymbolicBFI( InnerProduct( outer(V_vec, n), grad(ux,uy) ),\
                               BND, skeleton=True )
I cannot sure it is correct because I have no idea that the normal
n=specialcf.normal(2)
is a column vector nor a row vector.
In addition, if one codes like
CoefficientFunction((a,b,c,d), dims=(2,2))
the corresponding matrix is
[tex]\left(
\begin{array}{cc}
a & c \
b & d \
\end{array}
\right),[/tex]
nor
[tex]\left(
\begin{array}{cc}
a  & b \
c & d \
\end{array}
\right).[/tex]
Please help me, thank u.
Best wishes,
Di Yang
Hi Di Yang,
I think that the problem is that you’re using the wrong FESpace. VectorL2 should be the one you need:
V = VectorL2(mesh, order=3, dgjumps=True)
u, v = V.TnT()
jump_u = u - u.Other()
jump_v = v - v.Other()
mean_grad_u = 0.5 * (Grad(u) - Grad(u.Other()))
mean_grad_v = 0.5 * (Grad(v) - Grad(v.Other()))
a = BilinearForm(V)
a += InnerProduct(mean_grad_u * n, jump_v) * dx(skeleton=True)
a += InnerProduct(Grad(u) * n, v) * ds(skeleton=True)
Best wishes,
Henry
Hi Di Yang,
concerning your question about coefficient functions, the input is taken row-wise. For
cf = CoefficientFunction((1,2,3,4), dims=(2,2))
you can get out the components by
cf[i,j]
and I think evaluating (or drawing) the components is probably the quickest way to check the alignment.
Assume you have a mesh of the unit square, you could call
cf[0,1](mesh(0.5,0.5))
to get the output 2.
