Acceleration in Linear Elasticity
Hi everyone,
I’m trying to input acceleration along z axis in a simple linear elasticity problem.
The shape of the result look good, but the displacements are out of range.
I’m shearching for a solution but I’m out of ideas. If you have any solution.
This is my complet code.
# Variable
E = 210000
nu = 0.3
rho = 7810e-9
acc = 100000 # Acceleration
# Dirichlet Boundaries
Face_Dirichletx = 'Face4'
Face_Dirichlety = 'Face4'
Face_Dirichletz = 'Face4'
# Degree of Element
EleDeg = 2
# Mesh the geometrie and get the boundaries --------------------------------------------------
box = Box((0,-10,-10), (200,10,10))
box.faces.Max(X).name="Face4"
box.faces.Min(X).name="Face2"
geo = OCCGeometry(box)
mesh = Mesh(geo.GenerateMesh(maxh=6)).Curve(3)
boundaries = list(mesh.GetBoundaries())
# Calculation of Acceleration -----------------------------------------------
FonctionVolume = CoefficientFunction(1)
volume = Integrate(FonctionVolume, mesh)
NbNod = mesh.nv
NbMai = mesh.ne
NodeAcc = (rho * volume * acc) / (NbNod)
print("NbNode", NbNod)
print("Volume", volume)
print("mass", rho * volume)
print("NodeAcc", NodeAcc)
ACC = CF((0,0,NodeAcc))
# FE Space ---------------------------------------------------------------------------------
fes = VectorH1(mesh, order=EleDeg, dirichletx=Face_Dirichletx, dirichlety=Face_Dirichlety, dirichletz=Face_Dirichletz)
u, v = fes.TnT()
# Stress function ---------------------------------------------------------------------------------
def Stress(strain):
    print("Calculation of Stress")
    mu = E / 2 / (1 + nu)
    lam = E * nu / ((1 + nu) * (1 - 2 * nu))
    return 2 * mu * strain + lam * Trace(strain) * Id(3)
# Assemble of a ----------------------------------------------------------------------------
    a += SymbolicEnergy(InnerProduct(Stress(Sym(Grad(u))), Sym(Grad(u))))
    pre = Preconditioner(a, "bddc")
    a.AssembleLinearization(gfu.vec)
# Assemble of f with acceleration ---------------------------------------------------------
# f = LinearForm(ACC * v * dx).Assemble()
f += SymbolicLFI(ACC*v)
# Run the Solver --------------------------------------------------------------------------
inv = CGSolver(a.mat, pre, printrates='\r', tol=1e-6, maxiter=500)
Draw(gfu)
Thanks in advance.
Thomas
Hi Thomas,
to get from acceleration to displacement you have to integrate twice in time. I guess you want to use some time-stepping method for that.
Here is a lecture for solving the scalar wave equation, it is very similar for linear elasticity:
https://jschoeberl.github.io/IntroSC/PDEs/waveequation.html
I see what you mean, but I have maybe an easier solution.
I would like to apply a force along the Z axis on every nodes of the mesh.
To calculate the value of this force, I use this expression:
NodalForce = (rho * volume * acc) / (NbNod)
The NodalForce in Newton is called NodAcc in my last code.
I’ve tried this methode in a famous EF code and it work :
I found the exact same value between the model with acceleration and the model with the nodal loads (linear solver).
In my ngsolve script, I’ve noted that when I change the mesh density, the displacements results change, it mean that the force I’ve introduced is not only on nodes.
How to introduce nodal forces on every nodes ?
Thanks
Thomas.
to get acceleration from the force density you want to solve with the mass matrix
I don’t understand,
I don’t want to get acceleration from the force density,
I want to know how to apply force on nodes.
if i understand you correctly, you can create a gf on a space with order 1 and set the (nodal) values of the vector. them you can use this gf in your higher order problem
Yes it should work, but how to use the gf in the problem ?
I made a gf like this:
fes = VectorH1(mesh, order=1, dirichletx=Face_Dirichletx,
NFCF = CF((0,0,NodalForce))
gfu.Interpolate(NFCF)
but then I don’t succeed to use it in my f definition:
f += gfu.Interpolate(ACC)
How to do it ?
Thanks a lot for your help.
Thomas
f += gfu * v * dx
IT WORK !!!
I found my mistake, I thought that dx allowed to integrate on nodes, but in fact, it integrate on volume.
Thanks a lot, Joachim and Christopher for your help and your quick answer.
