Access GridFunction with Coordinates
Hello all,
I am relatively new to NGSolve/NETGEN and came across the following problem:
A short description of what I am doing:
I am trying to solve Poisson’s Equation for a 3D model of a simple spine model I created with NETGEN. This should give me, for a given electric dipole in the spine, potentials on the surface of the spine. This is part of the forward problem so I then later can solve the inverse problem (e.g. with sLORETA)
After doing some basic definitions for my problem:
fes = H1(mesh, order = '1')     # define Finite Element Space
u,v = fes.TnT()                 # define Trial and Test Space
sigma_coeff_ = {"spine" : 0.22, "vertebre" : 0.0014, "disc" : 0.008, "neck" : 0.01 , "trachea" : 0.015 , "oesophagus" : 0.015}
sigma_coeff = CoefficientFunction([sigma_coeff_[mat] for mat in mesh.GetMaterials()])
# create bounded X-elliptic bilinear form
a += grad(v)*sigma_coeff*grad(u) * dx + 1e-8*sigma_coeff*u*v*dx
c = Preconditioner(a, "bddc")
# create bounded linear form
→ the changes of the linear form f are not in the code since they are not relevant ( I think) ←
I solved the equation with:
# Assemble equations
# Solve PDE
inv = CGSolver(a.mat, c.mat, printrates=False, precision=1e-8)
So far this should do the trick but if there are more elegant ways please let me know!
Now to my first problem/question:
I only want the access some points of the GridFunction (those points where my electrodes will be placed). So when I write:
pnts_electrode = mesh(0,0,1)
val_gfu = gfu(pnts_electrode)
Is this the correct way to access the value of the GridFunction gfu at some point in the mesh that is closest to (0,0,1) ?
Somehow I get an error that my point is not in the mesh, although it should be.
Many thanks in advance!
Regards,
Markus
So I just discovered one mistake and came right to the next problem:
I defined my mesh point as
pnts_electrode = mesh(np.array([0,0,1]))
and not as
After correcting this mistake, I got the following error message:
Exception has occurred: TypeError
call(): incompatible function arguments. The following argument types are supported:
1. (self: ngsolve.fem.CoefficientFunction, mip: ngsolve.fem.BaseMappedIntegrationPoint) → object
2. (self: ngsolve.fem.CoefficientFunction, x: float, y: Optional[float] = None, z: Optional[float] = None) → ngcomp::PointEvaluationFunctional
3. (self: ngsolve.fem.CoefficientFunction, arg0: numpy.ndarray[ngsolve.fem.MeshPoint]) → numpy.ndarray
Invoked with: <ngsolve.comp.GridFunctionD object at 0x1176d6840>, <ngsolve.fem.MeshPoint object at 0x10088c570>
So it seems to me I just have to pass the actual coordinates like:
val_gfu = gfu(0,0,1)
Unfortunately I then get a PointEvaluationFunctional and still not the actual value for these coordinates. Is there something like
val_gfu.Get()
I can do to access the value of the PointEvaluationFunctional ?
Hi Markus,
your first attempt with
is the way to go. Are you sure that the point (0,0,1) is in the mesh ?
If you post the whole example (including the mesh) we can have a look.
So I made a small example and while doing it I think I came across the mistake:
from ngsolve import Mesh, H1, CoefficientFunction, BilinearForm, LinearForm, grad, dx, Parameter, Preconditioner, Draw
from ngsolve import ElementId, VOL, TaskManager, GridFunction, CGSolver
from netgen.csg import Cylinder, OrthoBrick, CSGeometry, Pnt
from math import pi, cos, sin
##### CREATE MESH #####
maxh = 0.1
# create cylinder along z-axis with center at (x = 0.2 ,y = 0) and height going from z = 0 to z = 1
cyl = Cylinder(Pnt(0.2,0,0), Pnt(0.2,0,1) , 1) * OrthoBrick(Pnt(-1, -1, 0), Pnt(1.5, 1.5, 1))
geo = CSGeometry()
geo.Add (cyl.mat('test'))
mesh = geo.GenerateMesh(maxh = maxh)
mesh = Mesh(mesh)
###### FEM SETTINGS #####
# define conductivity on body
sigma_coeff_ = {"test" : 0.22}
##### ADD DIPOLE #####
# -- adding dipole by creating two sources with different sign close to each other --
# distance between the sources greater then maximal mesh size
max_mesh= maxh *1.1
# dipole location
x = 0
y = 0
z = 0.5
# dipole direction - in this case along z-axis
beta = pi / 2
alpha = 0
# dipole magnitude
p = Parameter(1)
# -- netgen implementation --
# add first source term
spc = f.space
mp1 = spc.mesh(x,y,z)
ei1 = ElementId(VOL, mp1.nr)
fel1 = spc.GetFE(ei1)
dnums1 = spc.GetDofNrs(ei1)
shape1 = fel1.CalcShape(*mp1.pnt)
for d1,s1 in zip(dnums1, shape1):
    f.vec[d1] += ( p.Get()*s1 )
# change coordinates of second source term
x1 = x + max_mesh * cos(beta) * cos(alpha)
y1 = y + max_mesh * cos(beta) * sin(alpha)
z1 = z + max_mesh * sin(beta)
# add second source term
mp2 = spc.mesh(x1, y1, z1)
ei2 = ElementId(VOL, mp2.nr)
fel2 = spc.GetFE(ei2)
dnums2 = spc.GetDofNrs(ei2)
shape2 = fel2.CalcShape(*mp2.pnt)
for d2, s2 in zip(dnums2, shape2):
    f.vec[d2] += ( - p.Get()*s2 )
##### SOLVE PDE #####
# Solve PDE
inv = CGSolver(a.mat, c.mat, precision=1e-8)
# Visualize Solution
Draw(gfu, mesh, 'potential')
##### DEFINE ELECTRODE POSITION AND CALCULATE SOLUTION #####
#mesh_elec = mesh(-0.8, 0, 0.5)      # does not work for this point
mesh_elec = mesh(-0.799, 0, 0.5)      # works for this point
gfu_elec = gfu(mesh_elec)
print(gfu_elec)
So it seems like although the point ( -0.8, 0, 0.5) is theoretically in the mesh, it is only at the very edge… what would be a proper way to work around this problem?
Thanks!
Markus
Hi Markus,
Since it is at a curved boundary the point is actually not in the mesh. I think the best option is to curve the mesh to the geometry then the point will be found:
mesh.Curve(3)
Works perfectly, thanks a lot!
Markus
Dear @joachim,
I’ve been pointed out to this thread to evaluate a GridFunction at some points. I’m trying to see how to apply your recommendation, considering that the API may have changed in 3 years.
First, is it correct to say that
can be shortened in one line gfu(0, 0, 1)? From my test on a 2D problem, it seems that passing directly the coordinates to the function call work (I suppose that the conversion to a MeshPoint is either done automatically or not needed anymore).
Also, I’m trying to get a vectorized evaluation, that is an array of coordinates to produce and array of function values. From a error message, I see that there seems to be a supported syntax (the 5th and last one), but not sure how it works.
TypeError: __call__(): incompatible function arguments. The following argument types are supported:
    1. (self: ngsolve.fem.CoefficientFunction, mip: ngsolve.fem.BaseMappedIntegrationPoint) -> object
    2. (self: ngsolve.fem.CoefficientFunction, x: typing.SupportsFloat | typing.SupportsIndex, y: typing.SupportsFloat | typing.SupportsIndex | None = None, z: typing.SupportsFloat | typing.SupportsIndex | None = None) -> ngcomp::PointEvaluationFunctional
    3. (self: ngsolve.fem.CoefficientFunction, arg0: ngsolve.fem.CoordinateTrafo) -> ngsolve.fem.CoefficientFunction
    4. (self: ngsolve.fem.CoefficientFunction, arg0: ngsolve.fem.MeshPoint) -> object
    5. (self: ngsolve.fem.CoefficientFunction, arg0: typing.Annotated[numpy.typing.ArrayLike, ngsolve.fem.MeshPoint]) -> numpy.ndarray
OK I’ve found in the i-tutorials/CoefficientFunctions the vectorized syntax which involves passing numpy arrays (one per coordinate) to the mesh() call and it return a numpy array of list (with a strange dtype, but it does the job). This list of points is accepted by the gfu() call.
Also, in this tutorial, it is explictly said
Note that myfunc(0.2,0.3) will not evaluate the function: one must give points in the form of MappedIntegrationPoints like mip above. The mesh knows how to produce them.
while in my case it worked: is it because of an API improvement, or because I’m in a special case?
For the reference, I’ve posted a code example to evaluate the solution function on a 2D mesh grid, using flattened numpy arrays: How to display equipotential lines for a 2D problem - #4 by pierre-haessig
Hi Pierre,
to evaluate at a point in physical coordinates, we search for the element containing the point, and express it in barycentric coordinates, then the function is evaluated.
There is a difference between CoefficientFunction, and GridFunction(which is a derived class from CoefficientFunction. GF has a pointer to the mesh, but a CF not necessarily has a mesh, thus the CF(mesh(0,0,1)) is needed.
best, Joachim
OK thanks for the detailed explanation. So if I summarize:
  • if f is a GridFunction, then f(x,y) works and is a shortcut for f(mesh(x,y))
  • if f is a CoefficientFunction, then the f(mesh(x,y)) long syntax is needed
yes, exact - with a small nuance: Only the long syntax has a vectorized version
