I try to refine this mesh adaptively, but it dies at a.Assemble() after 2 refinements, directly forcing the program to an end, even without an error message. But if I refine it uniformly, it keeps working even after 4 refinements. Does anyone have an idea about what is going on here? The following is part of my code.
Update: I rerun the program on a Linux machine, and it shows Segmentation fault (core dumped)
# solve for the free dofs
def SolveBVP():
# assemble the bilinear and the linear form
l.Assemble()
# set up boundary conditions
if lam > 0:
if has_dirichlet:
uh.Set(mesh.BoundaryCF(bc["d"]), BND)
elif has_dirichlet or has_robin:
new_dirichlet_dict = {**bc["d"], **bc["r"]}
uh.Set(mesh.BoundaryCF(new_dirichlet_dict), BND)
# solve the linear system
#c.Update()
#solvers.BVP(bf=a, lf=l, gf=uh, pre=c)
r = l.vec - a.mat * uh.vec
inv = CGSolver(a.mat, c.mat)
uh.vec.data += inv * r
def CalcError():
flux = d * grad(uh)
# interpolate finite element flux into H(div) space:
gf_flux.Set (flux)
# gradient-recovery error estimator
err = 1/d*(flux-gf_flux)*(flux-gf_flux)
eta2 = Integrate (err, mesh, VOL, element_wise=True)
eta2 = eta2.NumPy()
# Integrate ( *dx(element_boundary=True), mesh, VOL, element_wise=True)
max_eta2 = max(eta2)
sum_eta2 = sum(eta2)
errs.append((fes.ndof, sqrt(sum_eta2)))
# if we want to refine the mesh adaptively,
# we label the elements in need of refinements here
if bool_adaptive:
# *** MARK step
# Mark cells for refinement for which eta > frac eta_max for frac = .95, .90, ...;
# choose frac so that marked elements account for a given part of total error
frac = .95
delfrac = .05
part = .5
marked = zeros(mesh.ne, dtype=bool) # marked starts as False for all elements
sum_marked_eta2 = 0. # sum over marked elements of squared error indicators
while sum_marked_eta2 < part*sum_eta2:
new_marked = (~marked) & (eta2 > frac*max_eta2)
sum_marked_eta2 += sum(eta2[new_marked])
marked += new_marked
frac -= delfrac
for el in mesh.Elements():
mesh.SetRefinementFlag(el, marked[el.nr])
return sqrt(sum_eta2)
SolveBVP()
while CalcError() > tol and it < max_it:
SolveBVP()
it += 1
Thanks for your reply! I played around with it a little bit and found that it works if I directly solve it instead of using a preconditioner. Do you have any idea what is happening here?
Thanks! Please see attached. If you use direct solver instead (comment Line 110, 129-131, uncomment Line 134), or you set is_adaptive = False (Line 231), you can run it without any problem.
Thank you so much! I tried to install the latest nightly version on Windows, but it told me that some .dll files were missing. I also installed NGSolve-6.2.2305 with pip on my office desktop with a Ubuntu system. There it works, but still does not work while using preconditioners for adaptive mesh. It gives:
malloc(): unsorted double linked list corrupted
Aborted (core dumped)
