Adding geometry to .stl file
Hello, is it possible to add CSG geometry (such as a box or plane for boundary) to .stl file? I imported the .stl file via netgen.stl and being able to mesh it and save as .vol file but to perform Navier Stokes simulation via the geometry, I need to add box like geometry for boundary. You can have a look at the .stl file.
https://ngsolve.org/media/kunena/attachments/1379/image.stl
https://ngsolve.org/media/kunena/attachments/1379/image.vol
Attachment: image.stl
Attachment: image.vol
not directly, for such a case probably the most easy thing is to mesh the box and the object seperately and merge the surface meshes. Then you can create a volume mesh from the merged mesh, here is a tutorial on how to do this:
https://ngsolve.org/docu/latest/netgen_tutorials/working_with_meshes.html
