Hello all!
I have been working on adaptivity for eigenvalues recently. I am a bit confused with the autoupdate feature of GridFunctions. Is the update after a mesh refinement intended to erase the content of the GridFunction and resize the GridFunction vector into a null vector?
I would like to update the GridFunctions and obtain an updated GridFunction defined over the new mesh (an automatic interpolation), without loosing any data, if that makes sense.
Attached a small example. I would like the second output to be non zero. Specifically, an equivalent of gf_u1.Set(cos(x)) after mesh.Refine() (without resetting cosine, in this example).
from netgen.occ import unit_square
mesh = Mesh(unit_square.GenerateMesh(maxh=0.4))
fes = H1(mesh, order=1, autoupdate=True)
gf_u1 = GridFunction(fes, autoupdate=True)
gf_u1.Set(cos(x))
print("gf_u1.vec.FV().NumPy():\n", gf_u1.vec.FV().NumPy())
Thanks for the help,
Gabriel
