BH curve
Good morning community;
is there a way to implment bh curve using ngsolve :
i do somthing like
def nuf(u):
return Norm(grad(u))
nu=CoefficientFunction(nuf)
a+=nu*grad(u)*grad(v)*dx
but always i got nan values !
any tricks ?
Dear Lahoussaine,
what is the actual model you want to implement?
“Norm(grad(u))” does not seem to a suitable model in first place, as it leads to a singular matrix for grad(u) = 0.
I want something like
1/(B3+B2+B )
or :
3.8exp(2.17B*B)+396.2
I ve tried those expression but it gives always NAN;
Thankes for your reply
TBH, I have never seen any magnetic model like that (which might not mean a lot
I can’t see how the first one could give something reasonable for B=0.
Before using a nonlinear model, did you have a working version for a constant “nu”?
I fear, we need much more information to be able to help you.
def nuf(u):
IfPos(2.28-B,(1/(-0.003995B**3+0.005956B**2+0.00646B + 0.001925)), ((1902.211B-4266.42343)/0.016694669))
Here is my formule, but it doesn’t work
The problem is whenever i put norm(B) it returns NAN
even if the formula is well defined( 1/(B**2+1) for example )
Thank you and Sorry to not be claire
Unfortunately, I still miss some information: how is “B” defined?
Where does the “Norm” enter in "1/(B**2 + 1)
Which command did you use for assembly? Where exactly do you get NaN? Already in the matrix or only after solving, i.e. in the solution?
Could you maybe post a complete minimal example that reproduces your problem?
Here is the code :
u, v = fes.TnT()
mu_r = {“air”: 1, “magnet”: 1.1, “fer1”: 1000, “fer2”: 1000}
Definition des permeabilites -------------------------
def nuf(u):
return IfPos(B-2.28,(1/(-0.0039954722B**3+0.00595660B**2+0.00646251B + 0.001925625)), ((1902.211579B±4266.42343)/0.016694669))
B = Norm(grad(u))
nu_test = [nuf(B) if mat==“fer1” else 1.0/(mu0*mu_r[mat]) for mat in mesh.GetMaterials()]
nu = CoefficientFunction(nu_test)
a = BilinearForm(fes, symmetric=False)
a += nu *(grad(u)*grad(v))*dx
You still use Norm(grad(u)) in the bilinear form instead of nu.
Is this an oversight?
Did you call a.Assemble or a.AssembleLinearization further doen behind the dots?
Here is the reste of code
a += nu*(grad(u)*grad(v))*dx
f= LinearForm(fes)
j = CoefficientFunction(10*1e3)
a+=- (j*v) * dx(“magnet”)
def SimpleNewtonSolve(gfu, a, tol=1e-8, maxits=30): res = gfu.vec.CreateVector()
du = gfu.vec.CreateVector()
fes = gfu.space
for it in range(maxits):
print(“Iteration {:3} “.format(it), end=””)
a.Apply(gfu.vec, res)
a.AssembleLinearization(gfu.vec)
du.data = a.mat.Inverse(fes.FreeDofs()) * res
gfu.vec.data -= du
 # stopping criteria
   stopcritval = sqrt(abs(InnerProduct(du, res)))
   print("<A u", it, ", A u", it, ">_{-1}^0.5 = ", stopcritval)
  if stopcritval < tol:
       break
Solve the linear system
gfa = GridFunction(fes)
SimpleNewtonSolve(gfa, a)
Okay, there a couple of issues:
First of all, using grad(u) and grad(v) suggests that you are using the (auxiliary) scalar magnetic potential (H=-grad(u)). However, everywhere else you work like you’d use the vector potential (B=curl(A)), i.e. using nu=1/mu and j*v as loading term. So, to me, the whole formulation seems to be inconsistent. Could you recheck, please?
Second, when using a.AssembleLinearization(
), ngsolve will linearize the expressions it finds in the bilinear form in some way. However, the nu*grad(u)*grad(v) is a linearized form already.
When trying to linearize this term, you get NaN’s because of a division by zero (or a very small number) resulting from the norm (at B=0).
When you work with CFs representing already “linearized” forms,
they must not depend on trial functions but grid functions only.
So nu must not depend on “u” but “gfu” in this case.
Please note that I did not try to fix the example, so there may be some things that I have overlooked (also in my own explanations). I hope they are still useful though.
Thank you for your time, I will just try to clarify my problem one last time.
You will find below the code of the Linear solution.
Concerning the linear solution, the weak formulation has been simplified, so the equation might be not clear, sorry for that. However, this simulation has been validated both with a commercial solver and another FEA api.
My problem is not about the weak formulation but the way to carry on a NonLinear simulation, the NonLinearity coming from the nu expression which depend on B and thus on u.
The Nonlinear simulation is thus the same as the linear one but with nu(B)
The question is : How would you perform a Non linear algorithm iterating on nu ?
You’ll find below the linear code that worked for me
stator = Circle(center=(0, 0), radius=10, bc=“bc_rect_ext” )
rotor = Circle(center=(0, 0), radius=6)
circle_airgap = Circle(center=(0, 0), radius=7.5)
magnet1 = Circle(center=(0, 0), radius=7)
magnet_f = magnet1-rotor
airgap = circle_airgap-(magnet1)
stator_f = stator-circle_airgap
change domain name and maxh
magnet_f.Mat(“magnet”).Maxh(0.5)
rotor.Mat(“fer1”).Maxh(0.5)
stator_f.Mat(“fer2”).Maxh(0.5)
airgap.Mat(“air”).Maxh(0.5)
geo.Add(magnet_f)
geo.Add(rotor)
geo.Add(stator_f)
geo.Add(airgap)
FEM -------------------------------------------------
fes = H1(mesh, order=3, dirichlet=‘bc_rect_ext’)
u, v = fes.TnT()
mu0 = 4pi1e-7
nu_coef = [1/(mu0mu_r[mat]) for mat in mesh.GetMaterials()]
nu = CoefficientFunction(nu_coef)
a += nu
(grad(u)grad(v))dx
M=80000
1e3)
Mx = CoefficientFunction(M
cos(atan2(y,x))*1e0)
My = CoefficientFunction(0)
f += (Mxgrad(v)[1]-Mygrad(v)[0]) * dx(“magnet”)
gfa.vec.data = a.mat.Inverse(fes.FreeDofs()) * f.vec
In my previous post, I might have had a confusion of the meaning of nu. Is the your nu “H(B)” or “dH/dB” evaluated for some B? I am used to work with “incremental” coefficients, ie “dH/dB”. So if you do not so, then my second “issue” in my previous response is not valid.
Assuming that your nu if such that H = nu B, then a.AssembleLinearization(gfa.vec) will linearized it for you.
However, linearizing Norm(B) when B is zero, results in a division by zero. You can work around that as follows (see comments in the code below, in particular around “def nuf”):
u, v = fes.TnT()
mu0 = 4pi1e-7
def nuf(u):
# You need to avoid division by zero in the linearization! Either by perturbing the norm of by providing
# the linearized norm for the norm being close to zero.
# Perturbation
#B = Norm(grad(u)+CF((1e-6, 1e-6)))
# manual linearization
B = Norm(grad(u))
             (1/(-0.0039954722*B**3+0.00595660*B**2+0.00646251*B + 0.001925625)),
             IfPos(B - 1e-8,
                   (1902.211579*B+-4266.42343)/0.016694669,
                   1902.211579/0.016694669) # linearized nu (dh/dB) for small B
nu_coef = [nuf(u) if mat==“fer1” else 1.0/(mu0*mu_r[mat]) for mat in mesh.GetMaterials()]
a += nu*(grad(u)grad(v))dx
M=80000
1e3)
“SIMULATING” the first Newton step only
define gfa upfront
check that AssembleLinearization() does not give NaNs
Hope that helps!
Dear community,
This topic is very important in the field of electromagnetic analysis.
However, it appears that the full script has not yet been explained in this topic.
I believe that NGSolve may solve the nonlinear problem of magnetic permeability.
Because there exist simulation results of transformers calculated by Prof. Schoeberl.Gallery - Wiki (tuwien.ac.at)
I am trying to adapt the following tutorial to nonlinear problems.
Symbolic definition of forms : magnetic field — NGS-Py 6.2.2307 documentation (ngsolve.org)
However, the task has not yet been completed.
This is because I don’t know how to set the permeability for each element instead of the material.
I would be grateful if someone would give me on how to resolve this issue.
Daigo
Dear community,
I post code for the modified relaxation method whose convergence time is inferior to the Newton’s method.
Modified relaxation method:
Flux Distribution in DC Machines On-Load and Overloads | IEEE Journals & Magazine | IEEE Xplore
def ModifiedRelaxationMethod(fes, u, v, f, funcNu, omega=0.3, tol=1e-3, maxits=20):
    fesH1 = H1(fes.mesh, order=1, dirichlet="outer", nograds=True)
    nu = makeCf(fes.mesh, makeGf(fesH1, funcNu(makeVec(fes.mesh, curl(gfu).Norm()))))
    print (f"Initial value calculating...")
    gfu, a = solve(u, v, f, nu)
        print (f"Iteration {it+1:3}  ",end="")
        _gfu, _a = solve(u, v, f, nu)
        du = omega * (_gfu.vec.FV().NumPy()[:] - gfu.vec.FV().NumPy()[:])
        gfu.vec.FV().NumPy()[:] += du
        #stopping criteria
        stopcritval = np.sum(np.abs(du))/np.sum(np.abs(gfu.vec.FV().NumPy()[:]))
        print (f'err:{stopcritval:5.3f}, {curl(gfu).Norm()(fes.mesh(0,0,0.5)):.2f}T')
            break
    return gfu
All codes are shown in the colab below.
We know that Newton’s method is shorter in convergence time than the modified relaxation method.
Newton’s method:
Efficient Techniques for Finite Element Analysis of Electric Machines | IEEE Journals & Magazine | IEEE Xplore
\begin{align} u^{i+1}=u^i+\Delta u^i \\ \begin{cases} \delta A(u^i) \Delta u^i = -f^i \\ f^i = Au^i \end{cases} \end{align}
I believe the following content may shed some light on this question.
3.7 Nonlinear problems — NGS-Py 6.2.1808 documentation (ngsolve.org)
I have a question.
How would I be able to get \delta A(u^i) in Maxwell’s Equations?
Daigo
I only tried with two dimensinal problem, but Newtom method implemented in NGSolve works with magnetic problems as well.
I assumed magnetic reclutivity \nu _r = 1 + \left| B \right|^2 .
import os, sys
from numpy import *
d = 0.005
h = 0.002
xp = [-d/2, -d/2,   0,  d/2, d/2,   0]
yp = [ h/2,-h/2, -h/2, -h/2, h/2, h/2]
face1 = MoveTo(xp[0], yp[0]).LineTo(xp[1], yp[1]).LineTo(xp[2], yp[2]).LineTo(xp[5], yp[5]).Close().Face()
face2 = MoveTo(xp[2], yp[2]).LineTo(xp[3], yp[3]).LineTo(xp[4], yp[4]).LineTo(xp[5], yp[5]).Close().Face()
face = Glue([face1, face2])
face.faces.name = "air"
face.edges.Nearest((-d/2, 0, 0)).name = "left"
face.edges.Nearest(( d/2, 0, 0)).name = "right"
face.edges.Nearest((-d/4, h/2, 0)).name = "top_1"
face.edges.Nearest((-d/4,-h/2, 0)).name = "bot_1"
face.edges.Nearest(( d/4, h/2, 0)).name = "top_2"
face.edges.Nearest(( d/4,-h/2, 0)).name = "bot_2"
face.edges.Nearest(( 0, 0, 0)).name = "center"
face.vertices.Nearest((0, -h/2, 0)).name = "gnd_1"
face.vertices.Nearest((0,  h/2, 0)).name = "gnd_2"
face.edges[1].Identify(face.edges[3], "periodicy", IdentificationType.PERIODIC)
face.edges[4].Identify(face.edges[6], "periodicy", IdentificationType.PERIODIC)
from ngsolve import Mesh
geo = OCCGeometry(face, dim=2)
mesh = Mesh(geo.GenerateMesh(maxh=h/10, quad_dominated=True) )
fes = H1(mesh, order=2, dirichlet='center')
u = fes.TrialFunction()
v = fes.TestFunction()
a += (1.0 + Norm(grad(u))**2)*(grad(u)*grad(v) - 1e6*v*x)*dx
c = Preconditioner(a, type="bddc")
gfAz = GridFunction(fes)
gfAz.Set(-1e6*(1/6*x**3 - 1/2*(d/2)**2*x))
res = gfAz.vec.CreateVector()
w = gfAz.vec.CreateVector()
for n in range(7):
	a.Apply(gfAz.vec, res)
	a.AssembleLinearization(gfAz.vec)
	solvers.CG(sol=w.data, rhs=res.data, mat=a.mat, pre=c.mat, printrates='', tol=1e-16, maxsteps=10000)
#	w.data = a.mat.Inverse(fes.FreeDofs()) * res
	gfAz.vec.data -= w
