BlockMatrix Direct Solver
Dear NGSolve,
Is there a possibility to use a direct solver for a BlockMatrix?
I read through the Documentation and the NGS build-in solvers but I didn’t figure out how to use/adapt things.
Here is a small example
V = H1(mesh, order= 1)
u,v=V.TnT()
a=BilinearForm(V,symmetric=True)
a+=grad(u)*grad(v)*dx
f=LinearForm(V)
f+=v*dx
N=NumberSpace(mesh)
p,q=N.TnT()
b=BilinearForm(trialspace=V,testspace=N)
b+=u*q*dx
b.Assemble()
g=LinearForm(N)
g.Assemble()
K=BlockMatrix( [[a.mat,b.mat.T],[b.mat,None]] )
rhs=BlockVector( [f.vec,g.vec] )
gfu=GridFunction(V)
gfN=GridFunction(N)
sol=BlockVector( [gfu.vec,gfN.vec] )
sol.data=K.Inverse(inverse="pardiso")*rhs #???[/code]
Nepomuk
Hi Nepomuk,
as you have found: you cannot directly call a direct solver from a BlockMatrix
BlockMatrix entries can be everything, not only sparse matrices.
Recommendation:
use a product-space:
fes = H1(...) * NumberSpace(...)
(u,p), (v,q) = fes.TnT()
then NGSolve assembles one big sparse matrix.
If you want to build a big sparse matrix from blocks, you have to go via numpy, e.g. using the coordinate format, see attached example.
blocksparse.ipynb (3.2 KB)
Since 2023, is it now possible to use a direct solver? When trying to use MinRes with a BlockMatrix without a preconditioner, I get the error
assert (freedofs is None) != (pre is None) # either pre or freedofs must be given
Is there any simple way to solve the system for all dofs?
(If necessary, I can create a new thread)
if you solve a system using BlockMatrix / BlockVector, you also need a BlockMatrix preconditioner. An example is here:
https://docu.ngsolve.org/latest/i-tutorials/unit-2.6-stokes/stokes.html#Stokes-as-a-block-system
