We try to calculate stress and deformation of rectangular plates under pressure load.
For fixed edges (no displacement, no rotation) we use dirichlet boundary conditions. No problem.
Assuming that we have a plate with some “supported” edges, i.e. elements are restricted in displacement only in a certain direction, e.g. z-axis while rotation and displacement in x/y is allowed.
How could that be specified in .py code. My assumption is that something of the dof of the relevant elements has to be modified, the question is what and how?
The “support” constraints should be applied to the “supported” bc in the model below
import ngsolve
import netgen
from netgen.csg import *
from netgen.meshing import *
import ngsolve.internal
a = 300.0
b = 100.0
t = 8.0
pressure = 0.01
cube = OrthoBrick( Pnt(-a/2 - 5, -b/2 - 5, -t), Pnt(a/2 + 5, b/2 + 5, 5) )
cube *= Plane(Pnt(0,0,0),Vec(0,0,1)).bc("force")
cube *= Plane(Pnt(-a/2,0,0),Vec(-1,0,0)).bc("supported")
cube *= Plane(Pnt(a/2,0,0),Vec(1,0,0)).bc("supported")
cube *= Plane(Pnt(0,-b/2,0),Vec(0,-1,0)).bc("wall")
cube *= Plane(Pnt(0,b/2,0),Vec(0,1,0)).bc("wall")
geo = CSGeometry()
geo.Add (cube)
mesh = Mesh(geo.GenerateMesh(maxh=3))
# What should be done to supported bc ?
fes = H1(mesh, order=2, dirichlet="wall", dim=mesh.dim)
u,v = fes.TrialFunction(), fes.TestFunction()
# linear strain tensor
def epsilon(u):
return 0.5 * (u.Deriv().trans + u.Deriv())# material parameters
E = 1200
nu = 0.35
# lame parameters
mu = 1/2*(E / (1+nu))
lam = E * nu / ((1+nu)*(1-2*nu))
a += SymbolicBFI( 2*mu*InnerProduct(epsilon(u),epsilon(v)) + lam*Trace(u.Deriv())*Trace(v.Deriv()))
force = CoefficientFunction( (0,0,-pressure) )
f += SymbolicLFI( force*v, definedon=mesh.Boundaries("force"))
u = GridFunction(fes,name="displacement")
u.vec.data = a.mat.Inverse(fes.FreeDofs())*f.vec
Draw(u)
# linear stress tensor
def stress(u):
return 2*mu*epsilon(u) + lam*Trace(epsilon(u))*Id(mesh.dim)
Draw(stress(u),mesh,"stress")
