Sorry – I was wrong yesterday when I reported that the build completed correctly. I deleted the build and install directories and repeated the build steps.
cmake "../src" -DCMAKE_INSTALL_PREFIX="BASEDIR/install" -G "Visual Studio 16 2019" -A "x64"
cmake --build . --config Release --target install
This time I noticed an error in the build that I had missed.
-- Installing: C:/UsersDow/ngsuite/install/Lib/site-packages/ngsolve/labextension/labextension
-- Installing: C:/UsersDow/ngsuite/install/Lib/site-packages/ngsolve/labextension/labextension/plugin.js
-- Installing: C:/UsersDow/ngsuite/install/Lib/site-packages/ngsolve/labextension/labextension/plugin.js.map
-- Installing: C:/UsersDow/ngsuite/install/Lib/site-packages/ngsolve/labextension/package.json
File "c:\users\dow\appdata\local\programs\python\python38\lib\runpy.py", line 194, in _run_module_as_main
return _run_code(code, main_globals, None,
File "c:\users\dow\appdata\local\programs\python\python38\lib\runpy.py", line 87, in _run_code
exec(code, run_globals)
File "C:\Users\Dow\AppData\Local\Programs\Python\Python38\Scripts\jupyter-nbextension.exe\__main__.py", line 7, in <module>
File "c:\users\dow\appdata\local\programs\python\python38\lib\site-packages\jupyter_core\application.py", line 270, in launch_instance
return super(JupyterApp, cls).launch_instance(argv=argv, **kwargs)
File "c:\users\dow\appdata\local\programs\python\python38\lib\site-packages\traitlets\config\application.py", line 664, in launch_instance
app.start()
File "c:\users\dow\appdata\local\programs\python\python38\lib\site-packages\notebook\nbextensions.py", line 983, in start
super(NBExtensionApp, self).start()
File "c:\users\dow\appdata\local\programs\python\python38\lib\site-packages\jupyter_core\application.py", line 259, in start
self.subapp.start()
File "c:\users\dow\appdata\local\programs\python\python38\lib\site-packages\notebook\nbextensions.py", line 711, in start
self.install_extensions()
File "c:\users\dow\appdata\local\programs\python\python38\lib\site-packages\notebook\nbextensions.py", line 682, in install_extensions
full_dests = install(self.extra_args[0],
File "c:\users\dow\appdata\local\programs\python\python38\lib\site-packages\notebook\nbextensions.py", line 206, in install_nbextension_python
m, nbexts = _get_nbextension_metadata(module)
File "c:\users\dow\appdata\local\programs\python\python38\lib\site-packages\notebook\nbextensions.py", line 1117, in _get_nbextension_metadata
m = import_item(module)
File "c:\users\dow\appdata\local\programs\python\python38\lib\site-packages\traitlets\utils\importstring.py", line 42, in import_item
return __import__(parts[0])
ModuleNotFoundError: No module named 'ngsolve'
app.start()
self.subapp.start()
File "c:\users\dow\appdata\local\programs\python\python38\lib\site-packages\notebook\nbextensions.py", line 891, in start
self.toggle_nbextension_python(self.extra_args[0])
File "c:\users\dow\appdata\local\programs\python\python38\lib\site-packages\notebook\nbextensions.py", line 864, in toggle_nbextension_python
return toggle(module,
File "c:\users\dow\appdata\local\programs\python\python38\lib\site-packages\notebook\nbextensions.py", line 477, in enable_nbextension_python
return _set_nbextension_state_python(True, module, user, sys_prefix,
File "c:\users\dow\appdata\local\programs\python\python38\lib\site-packages\notebook\nbextensions.py", line 375, in _set_nbextension_state_python
I can’t find any error preceding this, but there were many warnings about “inconsistent dll linkage”.
I’m attaching the configure/build output along with my CMakeCache.txt
I also tried deleting the build and install directories and building in Visual Studio. The documentation says:
The only ‘.sln’ file in the build directory was ‘ngsuite.sln’, which I assume is the new name for ‘SUPERBUILD.sln’. I built the “INSTALL” project as instructed. The same warnings and errors were generated and the behavior of the installed application was the same (i.e. netgen runs but importing ngsolve in a python shell fails).
I don’t know what else to try at this point.
Dow
Attachment: build-output.txt
Attachment: CMakeCache_2020-06-29.txt
