Can't get information about domains from mesh file
Hello, everyone. For my calculation I have to get file in .xml format from my mesh, for this purpose I use Dolfin-convert. For creating mesh I use Netgen. My sample is simple and looks like this
`algebraic3d
solid cube1 = plane (0,0,0;-1,0,0 )
and plane (1,1,1; 1,0,0 )
and plane (0,0,0; 0,-1,0)
and plane (1,1,1; 0, 1,0 )
and plane (0,0,0.3; 0,0,-1 )
and plane (1,1,1; 0,0, 1 );
solid cube2 = plane (0,0,0; -1,0,0 )
and plane (0,0,0; 0,-1,0 )
and plane (0,0,1.1; 0,0,-1 )
and plane (1,1,2.1; 0,0, 1 );
solid cube3 = plane (0,0,0; -1,0,0 )
and plane (0,0,1.0; 0,0,-1 )
and plane (1,1,1.1; 0,0, 1 ) -maxh=0.05;
tlo cube3;
tlo cube1;
tlo cube2;`
I’m getting mesh, but in my .xml file I don’t have information about domains, I have only:
mesh celltype=“tetrahedron” dim=“3”
cells size=“18584”
tetrahedron index=“” v0=“” v1=“” v2=“” v3=“”
mesh_function type=“uint” dim=“2” size=“37838
entity index=”" value=“”
mesh_function type=“uint” dim=“3” size=“18584
entity index=”" value=“”.
When I ask about it in Dolfin community they told that it’s problem in mesh. Could you help me to get why it doesn’t give information about domains? Thanks.
first, you may want to name your faces ( with .bc(“name1”) ) and materials ( with .mat(“material3”) ).
The dolfin - export was an external contribution to Netgen long time ago, and looks like it does not care about region names, see:
Playing the ball back to the fenics/dolfin community, maybe someone from them could help putting the region labels into the right places.
Or you go via meshio to convert a Netgen mesh to Dolfin.
