I’m trying to build Netgen/Ngsolve using the following configuration – I think it used to work in this environment.
cmake \
-DCMAKE_C_COMPILER=$GCC_DIR/bin/gcc \
-DCMAKE_CXX_COMPILER=$GCC_DIR/bin/g++ \
-DCMAKE_INSTALL_PREFIX=$INSTALL_DIR -DCMAKE_BUILD_TYPE=Release -DUSE_GUI=OFF \
-DUSE_MPI=ON \
-DUSE_MUMPS=ON \
-DUSE_HYPRE=ON \
-DUSE_MKL=ON \
-DMKL_ROOT=/opt/intel/mkl \
-DMKL_SDL=OFF \
../ngsolve
Cmake doesn’t report any errors, but when I run make, I get these errors:
[code][ 92%] Performing configure step for ‘ngsolve’
– Found Git: /usr/bin/git (found version “1.8.3.1”)
– The C compiler identification is GNU 7.2.0
– The CXX compiler identification is GNU 7.2.0
– Check for working C compiler: /vol/apps/gcc/gcc-7.2.0/bin/gcc
– Check for working C compiler: /vol/apps/gcc/gcc-7.2.0/bin/gcc – works
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Detecting C compile features
– Detecting C compile features - done
– Check for working CXX compiler: /vol/apps/gcc/gcc-7.2.0/bin/g++
– Check for working CXX compiler: /vol/apps/gcc/gcc-7.2.0/bin/g++ – works
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Detecting CXX compile features
– Detecting CXX compile features - done
– Found Netgen: /home/ddrake/NGserial/lib/cmake/netgen
– Looking for include file dlfcn.h
– Looking for include file dlfcn.h - found
– Looking for abi::__cxa_demangle
– Looking for abi::__cxa_demangle - found
– Found MKL: /opt/intel/mkl/include
– Found HYPRE: /home/ddrake/NGparallel/build/dependencies/src/project_hypre/src/hypre/lib/libHYPRE.a
– Found MUMPS: /home/ddrake/NGparallel/build/dependencies/src/project_mumps/lib/libdmumps.a;/home/ddrake/NGparallel/build/dependencies/src/project_mumps/lib/libzmumps.a;/home/ddrake/NGparallel/build/dependencies/src/project_mumps/lib/libmumps_common.a;/home/ddrake/NGparallel/build/dependencies/parmetis/lib/libparmetis.a
– Could NOT find LAPACK (missing: LAPACK_DIR)
– Could NOT find Sphinx (missing: SPHINX_EXECUTABLE)
Sphinx not found, if you want to build the documentation you have to install Sphinx
NGSolve 6.2.1804-67-ga81fb5a: Automatic configuration OK.
Build type: Release
Compiler: /vol/apps/gcc/gcc-7.2.0/bin/g++
Flags: -O3 -DNDEBUG -DHAVE_NETGEN_SOURCES -DHAVE_DLFCN_H -DHAVE_CXA_DEMANGLE -DUSE_TIMEOFDAY -DTCL -DUSE_PARDISO -DLAPACK -DHYPRE -DUSE_MUMPS -DNGS_PYTHON -DUSE_UMFPACK -march=native <<COMPILE_LANGUAGE:CXX>:-std=c++14> -fPIC
Enabled functionality:
GUI: ............... ON
LAPACK: ............ ON
MKL: ............... ON
PYTHON: ............ ON
MPI: ............... OFF
CUDA: ..............
MUMPS: ............. ON
PARDISO: ........... OFF
INTEL_MIC: ......... OFF
VTUNE: ............. OFF
VAMPIRTRACE: ....... OFF
Building:
Type 'make' to compile NGSolve.
Type 'make install' to install NGSolve.
Install directory:
– Configuring done
CMake Error: CMake can not determine linker language for target: dummy_fortran
CMake Error in linalg/CMakeLists.txt:
Exporting the target “dummy_fortran” is not allowed since its linker
language cannot be determined
CMake Error: Cannot determine link language for target “dummy_fortran”.
– Generating done
CMake Warning:
Manually-specified variables were not used by the project:
USE_GUI
[/code]
Thanks,
Dow
