Conjugate of a complex grid function solution
I’m solving a PDE for which the solution is complex. In the post-processing, I would like to compute an integral over the domain involving the inner product of the solution and its complex conjugate integrated over the domain (for example as you would do when working out the L2 inner product).
I’ve tried the InnerProduct function integrated over the domain, but this returns a complex rather than a real value:
Integrate(InnerProduct(gfu,gfu),mesh)
I’ve tried
Integrate(InnerProduct(gfu,gfu.conjugate),mesh)
But it didn’t accept this I’ve also tried to define a new bilinear form, but it does not like the attribute .conjugate on the weight function.
Is there a simple solution to this problem?
Many thanks
Ben
Integrate(InnerProduct(gfu,Conj(gfu)),mesh)
should work. You still get a complex as return value, but can use “.real” to get what you want.
