CoordinateTrafo causes segmentation fault with GridFunction-based CoefficientFunction (regression in 6.2.2503)
I found a regression bug in NGSolve. Using CoordinateTrafo with a CoefficientFunction derived from GridFunction causes segmentation faults in versions 6.2.2503 through 6.2.2506.
Environment
  • OS: Windows 10/11
  • Python: 3.12
  • NGSolve versions tested: 6.2.2406 ~ 6.2.2506
Version Test Results
| Version | Result | Notes |
| 6.2.2406 | OK | Works correctly |
| 6.2.2501 | OK | Works correctly |
| 6.2.2502 | N/A | Could not install (dependency issue with netgen-mesher) |
| 6.2.2503 | CRASH | Segmentation fault |
| 6.2.2504 | CRASH | Segmentation fault |
| 6.2.2505 | CRASH | Segmentation fault |
| 6.2.2506 | CRASH | Segmentation fault |
| 6.2.2506-139-ga14a97920 | OK | Works correctly (nightly build) |
Regression introduced in 6.2.2503, fixed in nightly build (6.2.2506-139-ga14a97920).
Minimal Reproducible Example
import ngsolve
print(ngsolve.__version__)
from numpy import *
from ngsolve.fem import CoordinateTrafo
# Create mesh
cyl = Cylinder(Pnt(0, 0, 0), Z, r=2, h=1)
geo = OCCGeometry(cyl)
mesh = Mesh(geo.GenerateMesh(maxh=0.3))
# Create HCurl GridFunction
fesHCurl = HCurl(mesh, order=1)
theta = atan2(y, x)
gfE = GridFunction(fesHCurl)
gfE.Set((-y * IfPos(theta, 1, 0) * IfPos(pi/4 - theta, 1, 0),
x * IfPos(theta, 1, 0) * IfPos(pi/4 - theta, 1, 0), 0))
# Create CoefficientFunction from GridFunction
Q = 0.5 * InnerProduct(gfE, gfE)
# Apply CoordinateTrafo - THIS CAUSES CRASH
phi = pi/4
trafo_cf = CF((cos(phi)*x + sin(phi)*y, -sin(phi)*x + cos(phi)*y, z))
trafo = CoordinateTrafo(trafo_cf, mesh.Materials(".*")) # <-- Crash here or next line
Q_rotated = Q(trafo)
# Set to GridFunction
fesH1 = H1(mesh, order=1)
gfQ = GridFunction(fesH1)
gfQ.Set(Q_rotated) # <-- Or crash here
Draw(gfQ, mesh, "Q", order=1)
Expected Behavior
The code should apply coordinate transformation to the CoefficientFunction and display the rotated field without crashing.
Actual Behavior
  • In versions 6.2.2503 ~ 6.2.2506: Segmentation fault occurs
  • Crash happens during script execution (not always at the same point)
  • Versions 6.2.2406 and 6.2.2501 work correctly
Working Versions
  • 6.2.2406: OK
  • 6.2.2501: OK
  • 6.2.2506-139-ga14a97920 (nightly/development build): OK
Conclusion
This is a regression bug introduced in version 6.2.2503. The bug has been fixed in the nightly build (6.2.2506-139-ga14a97920).
Workaround: Use version 6.2.2501 or earlier until the fix is released in a stable version.
Questions
  1. Is the fix in nightly build planned to be included in the next stable release (6.2.2507)?
  2. Is there a specific commit that fixed this issue?
Thank you for your help.
Appendix: Full Test Script
import sys
from numpy import pi, cos, sin
import ngsolve
version = ngsolve.__version__
print(f"NGSolve version: {version}")
from ngsolve import Mesh, HCurl, H1, GridFunction, CF, InnerProduct, atan2, IfPos, x, y, z
from netgen.occ import Cylinder, Pnt, Z, OCCGeometry
# Step 1: Create mesh
# Step 2: Create GridFunction
theta = atan2(y, x)
# Step 3: Create CoordinateTrafo
phi = pi/4
# Step 4: Apply transformation
# Step 5: Set to GridFunction
gfQ.Set(Q_rotated)
# Step 6: Multiple rotations
for n in range(4):
phi = n * pi / 4
gfQ.Set(Q_rotated)
print(f"[{version}] SUCCESS")
Hi, this should be fixed in newer ngsolve versions. Can you try a nightly build with
pip install --pre --upgrade ngsolve
Draw(Q_rotated,mesh)
Causes a bad_alloc. But for gfQ.Set(Q_rotated) the drawing Draw(gfQ) works well.
Best regards, Simon.
Visualization tries to evaluate exactly at the boundary and for uncurved mesh it is then outside and causes a range exception (there are no checks there).
If you mesh.Curve(5) it works for me.
Interpolation only evaluates at the interior where its safe as long as the uncurved mesh is fine enough at the boundary to not get external points.
