"Didn't find pointer" message whist using multiprocessing
I am having an issue whilst using NGSolve version 6.2.1908 in parallel on a Linux machine. The same code works on a Linux machine running NGSolve version 6.2.1905-45-g73eb677a and works for mac using 6.2.1905.
part of the message received was
Loading a nullptr
Typeids are different: ngfem::CoefficientFunction vs ngfem::ConstantCoefficientFunction
Reading pointer of type std::__cxx11::basic_string<char, std::char_traits, std::allocator >
Didn’t find pointer, create new registry entry at 0Loading a nullptr
Store a possibly more complicated pointer
Writeout version needed = Loading a nullptr
Reading pointer of type std::__cxx11::basic_string<char, std::char_traits, std::allocator >Pickling output for object of type ngfem::CoefficientFunction = ([b’\xfd\xff\xff\xff"\x00\x00\x00ngfem::ConstantCoefficientFunction\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xf0?‘, b’\x00\x00\x00\x00\x00\x00\x00\x00’, b’\x00\x00\x00\x00\x00\x00\x00\x00’],)
As far as I can tell the results obtained are still the same but there is a significant decrease in performance.
Kind regards,
Ben
Yes we added a lot more debug output while pickling… This is way too much for normal program run. As a workaround you can set the ngsglobals.msg_level down, we will reduce the default logging output from debug to info in future releases.
Thanks for reporting,
Hi Christopher,
That’s excellent, thank you for your help.
Kind regards,
Ben
