Differentiation of symbolic expressions
I am trying to understand how symbolic differentiation works in NGSolve for coefficient-dependent bilinear forms.
Suppose I have:
V = H1(mesh, order=2)
Q = L2(mesh, order=0)
u, v = V.TnT()
g, dg = Q.TnT()
cf = g * InnerProduct(grad(u), grad(v))
My goal is to compute the derivative of the stiffness matrix with respect to the L2 coefficient field g.
I understand that:
cf.Diff(g)
produces something equivalent to
But I am still confused about how this maps to assembled matrices.
Questions:
  1. Is cf.Diff(g) the correct symbolic representation of the derivative of the bilinear form with respect to g?
  2. If Q = L2(order=0), should the derivative with respect to each L2 dof correspond to one sparse matrix localized on one element?
  3. Is there a built-in way to assemble the tensor
    \frac{\partial A_{mn}}{\partial g_i}
    directly, rather than manually looping over L2 basis functions?
  4. Is there a way to inspect/debug the symbolic expression tree generated internally by Variation or Diff?
I would also appreciate clarification on the conceptual distinction between:
  • differentiating w.r.t. a GridFunction
  • differentiating w.r.t. a proxy function from Q.TnT()
Thanks!
Hi Alberto,
with print (expression) you get the representation of the expression tree.
expression.Diff(g) does not care what kind of CoefficientFunction g is, it just differentiates w.r.t this symbol. Try `print (g.Diff(g)), you should get 1.
You can also compute Gateaux-derivatives, e.g.
(g*g).Diff(g, dg) *will return 2*g*dg.
See also* Solving nonlinear Elasticity — NGS-Py 6.2.2604 documentation
