I’m writing a firedrake code using netgen to generate meshes which I then adaptivly refine. For this I have the following code to load/generate meshes:
from firedrake import *
import netgen
def generate_ng_square_circle1( h_max ):
circle_pnts = [(0, 0), (1, 0), (1, 1),
(0, 1), (-1, 1), (-1, 0),
(-1, -1), (0, -1), (1, -1)]
square_pnts = [(2, 2), (-2, 2), (-2, -2), (2, -2)]
p1, p2, p3, p4, p5, p6, p7, p8, p9 = [geo.AppendPoint(*pnt) for pnt in circle_pnts]
p10, p11, p12, p13 = [geo.AppendPoint(*pnt) for pnt in square_pnts]
circle = [[["spline3", p2, p3, p4], "curve"],
[["spline3", p4, p5, p6], "curve"],
[["spline3", p6, p7, p8], "curve"],
[["spline3", p8, p9, p2], "curve"]]
square = [[["line", p10, p11], "line"],
[["line", p11, p12], "line"],
[["line", p12, p13], "line"],
[["line", p13, p10], "line"]]
[geo.Append(c, bc=bc, leftdomain=0, rightdomain=1) for c, bc in circle]
[geo.Append(c, bc=bc, leftdomain=1, rightdomain=0) for c, bc in square]
ngmsh = geo.GenerateMesh(maxh=h_max)
return ngmsh
def load_or_generate_mesh( mesh_name, h_max=0.4 ):
vol_file = f"meshes/{mesh_name}_{str(h_max).replace('.', '')}.vol"
if os.path.exists(vol_file):
ngmsh = netgen.meshing.Mesh()
ngmsh.Load(vol_file)
print(f"loaded mesh from {vol_file}")
mesh_function = globals().get(f"generate_{mesh_name}")
if mesh_function is None:
raise ValueError(f"no mesh or generator with the name {mesh_name} found.")
ngmsh = mesh_function(h_max)
ngmsh.Save(vol_file)
print(f"saved mesh to {vol_file}")
mesh = Mesh(ngmsh)
return mesh
I then use netgen adaptive refiinement to refine these meshes.
Now the problem is that I get a different refined mesh when I generated the mesh directly compared to when i generated it earlier and then loaded it from the .vol file.
When generating the mesh directly and then refining I get this:
When loading the already generated mesh from a .vol file and refining I get this:
Can I somehow save/load in a different way so that the geometry of the boundry also gets saved and then adapted correctly?
