Div(a*Grad(v))
Hello all,
i am trying to calculate almost an Laplacian div( a * Grad(v) ) for 1-dim a and 2-dim v. They are both “ComponentGridFunctions”.
However, I get the error that the Coefficient Functions object does not have the attribute ‘derivname’.
that’s not expected to work. You can apply (certain) differential operators to Grid- and Proxy-Functions, but not to arbitrary expressions.
Hello Joachim,
Thank you for your fast response.
I have tried to construct a GridFunction and use .Set() to interpolate the term a*Grad(v) to use the Div operator on that Grid function, but get the following error:
NgException: CompoundFESpace does not have an evaluator for VOL!
Is there another way to achive this laplacian in NGSolve or should I try to export my variables to numpy and do numerical differentation there.
The aim is to do post-processing and it would be nice to do it within ngsovle.
this one is working:
gfu = GridFunction(VectorH1(mesh, order=3))
gfu.Set ( (x*x*x, x*y*y) )
gfflux = GridFunction(HDiv(mesh, order=2)**2)
gfflux.Set ( 1/2 * Grad(gfu))
Draw (div(gfflux)[0], mesh)
Draw (div(gfflux)[1], mesh)
Product-spaces don’t provide differential operators, only their component spaces. Multiple copies of the same space (like HDiv(…)**2) inherit the diffops from the underlying space.
