Div of a Curl
I’ve been enjoying the updated iTutorials very much!
I noticed a small issue with the new HCurlDiv iTutorial, though…
It tries to compute the div of the curl of a grid function l in block 12, and fails like this:
Exception Traceback (most recent call last)
in ()
----> 1 div(uc)
~/ngsuite/ngsolve-install/lib/python3/dist-packages/ngsolve/utils.py in div(func)
84 if add:
85 return add
—> 86 raise Exception(“cannot form div”)
87
88
Exception: cannot form div
Just to see what would happen, I changed a line in utils.py (as below) and restarted the Jupyter kernel.
[code]def div(func):
if func.derivname == “div”:
if func.derivname in ["div", "curl"]:
    return func.Deriv()
add = func.Operator("div")
if add:
    return add
raise Exception("cannot form div")
[/code]
It seemed to work:
div(uc)
<ngsolve.comp.CoefficientFunction at 0x7fd22cce68e0>
Dow
Hi, that line was there to show that you cannot form the div of a function in HCurl (because its not implemented either as the default operator or as an additional operator). So it raises an exception.
The function .Deriv() returns the default derivative for the finite element space the Testfunction/Trialfunction/Gridfunction is defined on. We give a function from HCurl, so
returns true and with
return func.Deriv()
you return the curl of the function not the div…
Hi Christopher,
Thanks for clearing up my misunderstanding on this!
Dow
Hi dow!
Note however that the piecewise grad operator is exported for H(curl) function. By this you could for example implement (just for fun :D…) an H(curl) conforming dg vector laplce problem.
Thus you can easily implement the pice-wise div operator on your own.
Best, Philip
PS: I think grad(u) is actually the transpose…
