Element weighting
Hello everyone!
I’m working on a hyper-reduction method where each element in the mesh has a unique weight.
The weights must be applied to the local element stiffness matrices during the assembly to the bilinear form.
Is there a way of doing that given a vector of element weights?
Or else is there a way to get single element stiffness matrices in global coordinates?
Thank you
Nils
You can do this quite easily with a c++ extension. Basically you need to follow the first two steps of the c++ tutorial here: NGSolve Basics — NGS-Py 6.2.2302 documentation
You can for example parse the elementwise coefficients as a list or a numpy array and store them in a c++ array. Then in the evaluate function of your coefficient you query the element number by
int elnr = mip.GetTransformation().GetElementNr();
Then return the corresponding value from the array.
You can then use this CoefficientFunction in your stiffness bilinearform.
I hope this helps, if you run into problems write again. This part of the documentation is not often used yet.
Hello Christopher,
thank you for the help.
I got as far as making a CoefficientFunction that gives the element number.
But I need the CoefficientFunction to know the element weights. You said to store the weights in an array. At what point can I do that?
I tried to initialize with the array.
The idea was to initialize my custom CoefficientFunction like this:
cf = ElementWeightCF(weights)
But that didn’t work:
TypeError: __init__(): incompatible constructor arguments. The following argument types are supported:
    1. CppExtension.cppextension.ElementWeightCF()
It seems like the issue is to initialize the ngsolve CoefficientFunction with to many arguments.
You can find my .hpp file in the attachments.
How can I fix that issue or is there a better way of passing the element weights to my c++ CoefficientFunction?
Thanks in advance
Nils
https://ngsolve.org/media/kunena/attachments/1180/ElementWeightCF.hpp
Attachment: ElementWeightCF.hpp
Hi Nils,
the code in your hpp seems ok, I expect the problem is in the binding code. Can you send the cpp file as well?
You can find the remaining code in the attachments.
https://ngsolve.org/media/kunena/attachments/1180/ElementWeightCF.cpp
https://ngsolve.org/media/kunena/attachments/1180/cppextension.cpp
Attachment: ElementWeightCF.cpp
Attachment: cppextension.cpp
The export of the constructor is wrong, the template arguments for the py::init must be the arguments for the constructor:
.def(py::init<py::array_t<double>>())
best
Hello Christopher,
thank you! Now the weighting CoefficientFunction works.
For linear problems the everything works as expected but I want to apply the element weights to nonlinear problems as well.
When calling AssembleLinearization of the BilinearForm I get the following error:
    K_weighted.AssembleLinearization(u_full.vec)
Evaluate AutoDiff<double> not overloaded, type = class ngfem::MyElementWeightCFin Assemble Element Mat, bfi = Symbolic BFI in AssembleLinearization
Is there a way to make AssembleLinearization work with the custom CoefficientFunction?
Best regards
Nils
Hi
for this derive your function from CoefficientFunctionNoDerivative instead of CoefficientFunction
