I have Netgen5.3 installed in my PC, the netgen GUI program can mesh the ellipsoid.geo file quickly. Recently, I have tried to call the nglib::Ng_CSG_GenerateMesh() function in C++.
#include <iostream>
#include <fstream>
namespace nglib {
#include <nglib.h>
int main(int argc, char** argv)
using namespace nglib;
char file_name[256];
strcpy(file_name, argv[1]);
std::cout << file_name << std::endl;
// Initialise the Netgen Core library
nglib::Ng_Init();
long nvertices = 0;
long ntriangles = 0;
long ntetrahedrons = 0;
double* vertexlist = NULL;
int* trianglelist = NULL;
int* tetralist = NULL;
nglib::Ng_CSG_GenerateMesh(file_name, &nvertices, &ntriangles, &ntetrahedrons, vertexlist, trianglelist, tetralist);
// deconstruct Netgen library.
nglib::Ng_Exit();
return 0;
DLL_HEADER Ng_Result Ng_CSG_GenerateMesh (const char * filename, long *nvertices, long *ntriangles, long *ntetrahedrons, double * vertexlist, int * trianglelist, int * tetralist);
This code works fine with all the tutorials .geo files in the tutorials directory except the ellipsoid.geo file.
## An elliptic cylinder
algebraic3d
solid test = ellipsoid (0, 0, 0; 2, 0, 0; 0, 1, 0; 0, 0, 1) -maxh=0.5;
tlo test;
It takes a very long time to mesh and prints a lot of messages:
define solid test
Calc Triangle Approximation
Object 0 has 882 triangles
Start Findpoints
main-solids: 1
Found points 0
Analyze spec points
done
find points done
Find edges
Add line segment to smooth surface
0 edges found
Check intersecting edges
CalcLocalH: 2 Points 0 Elements 0 Surface Elements
Start Findpoints
main-solids: 1
Found points 0
Analyze spec points
done
Find edges
0 edges found
Start Findpoints
main-solids: 1
Found points 0
Analyze spec points
done
Find edges
0 edges found
Surface 1 / 1
load internal triangle rules
[b]faces = 66 trials = 1000 elements = 65 els/sec = 650000
faces = 113 trials = 2000 elements = 111 els/sec = 1.11e+06
faces = 141 trials = 3000 elements = 139 els/sec = 1.39e+06
faces = 174 trials = 4000 elements = 172 els/sec = 1.72e+06[/b]
I wonder if I need to set the Ng_Meshing_Parameters before meshing ellipsoid object?
Could someone give me a tip on how to generate ellipsoid object mesh correctly.
Thank you.
Wei
