I’m using NGSolve 6.2.2201 with python 3.8.10 and I get the following error when I call a visoption like
visoptions.deformation=0
ERROR: unexpected “,” outside function argument list
in expression “100,000000/100”
errinfo: unexpected “,” outside function argument list
(parsing expression “100,000000/100”)
invoked from within
“expr $status_percent/100”
(procedure “timer2” line 32)
invoked from within
"timer2 "
(“after” script)
Can you tell me, where the dog is hidden?
BR, Nepomuk
Could you post a full example?
The visoptions comands append tcl-commands to a queue, which are batch processed by the tcl timer.
I suspect that the actual problem is happening earlier.
The error disappeared, when I removed the matplotlib module. I wasn’t able to recreate the error in a minimum example, but in the one below, the GUI gets stuck (with or without the visoption command) if one imports matplotlib.pyplot.
Where does this come from?
BR, Nepomuk
import netgen.gui
ngsolve stuff
basic geometry features (for the background mesh)
from ngsolve.meshes import MakeStructured2DMesh
visualization stuff
geo=SplineGeometry()
geo.AddCircle((0,0),1,bc=“diri”,leftdomain=1,rightdomain=0)
mesh=Mesh(geo.GenerateMesh(maxh=0.1))
Vh=H1(mesh,order=1,dirichlet=“diri”)
u=Vh.TrialFunction()
v=Vh.TestFunction()
a=BilinearForm(Vh,symmetric=True)
f=LinearForm(Vh)
a+=InnerProduct(grad(u),grad(v))*dx
f+=CoefficientFunction(1.0)vdx
gfu=GridFunction(Vh)
gfu.vec.data=a.mat.Inverse(freedofs=Vh.FreeDofs())*f.vec
Draw(gfu,mesh,“gfu”)
input(“…”)
