I’ve tried installing ngsxfem in a million different ways now on my Silicon mac.
I’m now using virtual environments using micromamba (like conda), and install ngsolve successfully using pip install ngsolve.
However, when I then try to install ngsxfem by writing pip3 install xfem, I get the following cmake error message
CMake Error at CMakeLists.txt:74 (find_package):
Could not find a package configuration file provided by "NGSolve" with any
of the following names:
NGSolveConfig.cmake
ngsolve-config.cmake
Does anyone know how to fix this?
lets try installation #1.000.002:
pip3 install --pre xfem
with this I get xfem-2.1.2303.post64.dev0-cp312-cp312-macosx_10_15_universal2.whl installed
Thank you for your reply Joachim, unfortunately this gives me the same error message.
From
I get:
Collecting xfem
Using cached xfem-2.1.2303.post64.dev0-cp312-cp312-macosx_10_15_universal2.whl.metadata (645 bytes)
Collecting ngsolve>=6.2.2307.post90 (from xfem)
Using cached ngsolve-6.2.2402.post27.dev0-cp312-cp312-macosx_10_15_universal2.whl.metadata (199 bytes)
Collecting netgen-mesher==6.2.2402.post31.dev (from ngsolve>=6.2.2307.post90->xfem)
Using cached netgen_mesher-6.2.2402.post31.dev0-cp312-cp312-macosx_10_15_universal2.whl.metadata (174 bytes)
Using cached xfem-2.1.2303.post64.dev0-cp312-cp312-macosx_10_15_universal2.whl (1.2 MB)
Using cached ngsolve-6.2.2402.post27.dev0-cp312-cp312-macosx_10_15_universal2.whl (33.8 MB)
Using cached netgen_mesher-6.2.2402.post31.dev0-cp312-cp312-macosx_10_15_universal2.whl (43.1 MB)
Installing collected packages: netgen-mesher, ngsolve, xfem
Successfully installed netgen-mesher-6.2.2402.post31.dev0 ngsolve-6.2.2402.post27.dev0 xfem-2.1.2303.post64.dev0
Uninstall all you netgen-mesher and ngsolve packages, and show us what you get (from the beginning up to the problem)
Attached, you find the complete output after uninstalling ngsolve using pip, and then redoing the installations.
output.pdf (68.6 KB)
there are only xfem binary packages for Apple Silicon for Python 3.11 and 3.12 (universal.whl), see xfem · PyPI
your options are
- swtich to Py 3.11 or 3.12
- ask the xfem developers for universal wheels also for elder Py versions
- compile yourself
I created a clean virtual environment with no packages installed, and did the following:
- Install python3.12 using
micromamba install python=3.12.
- Install xfem by writing
pip3 install --pre xfem.
This succeeds with the output
Collecting xfem
Using cached ngsolve-6.2.2402.post34.dev0-cp312-cp312-macosx_10_15_universal2.whl.metadata (199 bytes)
Collecting netgen-mesher==6.2.2402.post37.dev (from ngsolve>=6.2.2307.post90->xfem)
Using cached netgen_mesher-6.2.2402.post37.dev0-cp312-cp312-macosx_10_15_universal2.whl.metadata (174 bytes)
Using cached ngsolve-6.2.2402.post34.dev0-cp312-cp312-macosx_10_15_universal2.whl (33.8 MB)
Using cached netgen_mesher-6.2.2402.post37.dev0-cp312-cp312-macosx_10_15_universal2.whl (43.1 MB)
Successfully installed netgen-mesher-6.2.2402.post37.dev0 ngsolve-6.2.2402.post34.dev0 xfem-2.1.2303.post64.dev0
However, if I enter python3 and type from xfem import *, I get the following error message, indicating that xfem was not installed for the ARM architecture. What am I doing wrong then?
>>> from xfem import *
File "<stdin>", line 1, in <module>
File "/Users/sebastianmyrback/y/envs/ngenv/lib/python3.12/site-packages/xfem/__init__.py", line 23, in <module>
from xfem.ngsxfem_py import *
ImportError: dlopen(/Users/sebastianmyrback/y/envs/ngenv/lib/python3.12/site-packages/xfem/ngsxfem_py.so, 0x0002): tried: '/Users/sebastianmyrback/y/envs/ngenv/lib/python3.12/site-packages/xfem/ngsxfem_py.so' (mach-o file, but is an incompatible architecture (have 'x86_64', need 'arm64e' or 'arm64')), '/System/Volumes/Preboot/Cryptexes/OS/Users/sebastianmyrback/y/envs/ngenv/lib/python3.12/site-packages/xfem/ngsxfem_py.so' (no such file), '/Users/sebastianmyrback/y/envs/ngenv/lib/python3.12/site-packages/xfem/ngsxfem_py.so' (mach-o file, but is an incompatible architecture (have 'x86_64', need 'arm64e' or 'arm64'))
The exact same thing happens if I try to do it with python3.11. I’m using macOS 14.4.1.
Hey,
We just updated the pip-packages for xfem and tried to support more Mac configurations. Please have another try.
Now I’m getting a segmentation fault instead:
(ngenv) sebastianmyrback@n168-p199 ~ % pip3 install --pre xfem
Collecting xfem
Using cached xfem-2.1.2303.post70.dev0-cp312-cp312-macosx_10_15_universal2.whl.metadata (645 bytes)
Using cached xfem-2.1.2303.post70.dev0-cp312-cp312-macosx_10_15_universal2.whl (2.2 MB)
Successfully installed netgen-mesher-6.2.2402.post37.dev0 ngsolve-6.2.2402.post34.dev0 xfem-2.1.2303.post70.dev0
(ngenv) sebastianmyrback@n168-p199 ~ % python3 -V
Python 3.12.2
Python 3.12.2 | packaged by conda-forge | (main, Feb 16 2024, 20:54:21) [Clang 16.0.6 ] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> from xfem import *
zsh: segmentation fault python3
