error on install ngsxfem
Dear ngsolve developer
Thank you for this versatility library. I have some issue on installing the ngsxfem, here is my procedure of the installation:
OS: ubuntu 20
I first use conda to install the ngsolve in the anaconda site package, all works well and I used it to do some calculation without any problem.
Then, I would like to install the ngsxfem to use some XFEM utils, now I have some problem:
I first tried to install it by pip3, installation had no problem. But when I import xfem in a python script, it poses an error like: from xfem.ngsxfem_py import *
ImportError: arg(): could not convert default argument into a Python object (type not registered yet?). Compile in debug mode for more information.
I was not sure what was going on, so I tried to install it from source, I followed the instruction on the site: clone the source (the most recent version 2.0) and build it. However, when I sudo make install, error occured:
[100%] Built target ngsxfem_py
Install the project…
– Install configuration: “”
– Up-to-date: /home/swu2019/anaconda3/lib/python3.8/site-packages/xfem/ngsxfem_py.so
– Up-to-date: /home/swu2019/anaconda3/lib/python3.8/site-packages/xfem/init.py
– Up-to-date: /home/swu2019/anaconda3/lib/python3.8/site-packages/xfem/cutmg.py
– Up-to-date: /home/swu2019/anaconda3/lib/python3.8/site-packages/xfem/mlset.py
– Up-to-date: /home/swu2019/anaconda3/lib/python3.8/site-packages/xfem/lset_spacetime.py
– Up-to-date: /home/swu2019/anaconda3/lib/python3.8/site-packages/xfem/lsetcurv.py
– Up-to-date: /home/swu2019/anaconda3/lib/python3.8/site-packages/xfem/utils.py
– Up-to-date: /home/swu2019/anaconda3/lib/python3.8/site-packages/xfem/ngs_check.py
importing ngsxfem-2.0
File “/home/swu2019/anaconda3/lib/python3.8/runpy.py”, line 194, in _run_module_as_main
return _run_code(code, main_globals, None,
File “/home/swu2019/anaconda3/lib/python3.8/runpy.py”, line 87, in _run_code
exec(code, run_globals)
File “/home/swu2019/anaconda3/lib/python3.8/site-packages/pybind11_stubgen/main.py”, line 4, in
main()
File “/home/swu2019/anaconda3/lib/python3.8/site-packages/pybind11_stubgen/init.py”, line 915, in main
_module = ModuleStubsGenerator(_module_name)
File “/home/swu2019/anaconda3/lib/python3.8/site-packages/pybind11_stubgen/init.py”, line 666, in init
self.module = importlib.import_module(module_or_module_name)
File “/home/swu2019/anaconda3/lib/python3.8/importlib/init.py”, line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1014, in _gcd_import
File “”, line 991, in _find_and_load
File “”, line 975, in _find_and_load_unlocked
File “”, line 671, in _load_unlocked
File “”, line 783, in exec_module
File “”, line 219, in _call_with_frames_removed
File “/home/swu2019/anaconda3/lib/python3.8/site-packages/xfem/init.py”, line 23, in
CMake Error at python/cmake_install.cmake:104 (file):
file INSTALL cannot find
“/home/swu2019/programming/PyPoroX/build-xfem/python/…/stubs/xfem-stubs”:
No such file or directory.
cmake_install.cmake:42 (include)
Cause the /home/swu2019/anaconda3/lib/python3.8/site-packages/ is the directory of the ngsolve, I set the location for the ngsxfem here.
I am very appreciate if you could help to finish the installation or give me some hint !!!
Shaoqi
Dear Shaoqi,
We haven’t worked with conda and ngsxfem so far, but it is not too surprising that the conda install of ngsolve and the pip/manual install of ngsxfem don’t work well together. Any chance you could simply install ngsolve without conda? E.g. through apt-get?
Thanks for your reply, it works !
Another question, The version installed from apt-get is sequential version ? If we want to do the parallelization or use some other options like MUMPS direct solver, we should build by ourselves the ngsolve from the source, right ?
Thank you very much again for this very quickly reply !
Best regards
Shaoqi
