I already have the next question: I want to explore the mesh topology. Namely I need the faces, that are connected to a vertex. After reading i-tutorial 1.8 my hope was that something like the following would be possible:
from netgen.occ import Z, Cylinder, OCCGeometry
cyl = Cylinder( (0,0,0), Z, r=1, h = 2)
cylf = cyl.MakeFillet(cyl.edges, 0.2)
mesh = Mesh(OCCGeometry(cylf).GenerateMesh(maxh=0.8,perfstepsend=MeshingStep.MESHSURFACE))
# is empty
mesh.vertices[0].faces
Unfortunately the returned tuple is empty. Do I need to polulate the face list before accessing it, or is this information not available and do I have to create own structures, that store this information?
Since faces store the correct vertices, e.g.
mesh.faces[0].vertices
returns the face vertices. So I could build a mapping in own data structures. I was just curious, why the face list is not directly available.
Maybe someone can give me a hint here?
you can go both directions in the topology, also vertex → faces.
We have stored the vertex → elements table, which is used to build vertex → faces on the fly, in O(1) complexity. It was overseen to loop also over the vertex → surfaceelements, just added it.
In the other solution you get sub-optimal complexity O(N).
thanks for this information. That is great. Indeed my idea was to build a map (hash table) on my own, to get good performance for the lookup. Great that this is already built in - I will give this a try!
