Hello, I work on a resolution with finite elements and I need to find a way to extract the correct coordinates and table of connectivity on the mesh for the order 2.
I explain,
I created a mesh and after that, I used this code to find the coordinates and table of connectivity
mesh.ngmesh.SecondOrder()
mesh.ngmesh.Coordinates()
listCoor = []
for i in mesh.ngmesh.Coordinates():
listCoor.append(i)
listCoor = np.array(listCoor)
#print(listCoor)
listConnectivity = []
for el in mesh.ngmesh.Elements2D():
listConnectivity.append([x.nr for x in el.points])
listConnectivity = np.array(listConnectivity)
#print(listConnectivity)
But after do that and made a resolution of my problem, when I took a look on the matrix, I saw that some locations given by the previous code lines don’t tally with the way in which the matrix is filled.
So, does it exist a way or a NGSolve command which would give directly the NGSolve mesh used for the resolution in order 2 or which would give the correct coordinates and table of connectivity on the mesh for the order 2
Thanks,
