does Netgen have an option (possibly accessible by a preprocessor using Netgen plug-in for meshing) to mesh with linear tetrahedrons and then convert them to second order by just adding nodes in the middle of the element edges ? In Gmsh, this can be achieved using the SecondOrderLinear option. The idea is to avoid the mid-side nodes being snapped to the geometry since it may lead to negative Jacobians in some cases with complex (or messy) CAD models. I haven’t found such a feature in Netgen yet. I’ve even seen some preprocessors setting second_order to 0 only to convert the meshes to 2nd order themselves for the same reason.
