H1-P0 FEM
Hello everyone!
V = H1(mesh, order=0)
and
Vbar =H1(mesh, order=0, orderinner=0, dirichlet=[1,2,3,4])
Can these two finite element spaces be used? and, do they have only one degree of freedom?
No the H1 space is only well defined for order >= 1. If you need a constant on the whole domain you can use the NumberSpace.
Best Christopher
Hi Christopher!
Now,can I define a constant on the skeleton?
Thanks!
Yongbin
The evaluator of the NumberSpace always returns the constant, so you should be able to use it in a skeleton formulation as well…
Did you try it?
Hi!
NumberSpace is the space V = FESpace(“number”,mesh) ?
Thanks!
Yongbin
Yes, better is the Python constructor: V = NumberSpace(mesh)
Hi Christopher!
In my code, I have to use the space with dirichelet bounary
V = NumberSpace(mesh, dirichlet=[1,2,3,4)
,It’s still usable in my code, But I think it’s strange. because the trial function is only 0, namely V=0 .
Many thanks
Yongbin Han
Hi Yongbin,
using a NumberSpace together with Dirichlet boundaries does not make sense to me. The NumberSpace gives a singe scalar unknown (1 dof). If this scalar is then constrained to be zero at the boundary, it will simply be zero and there are no free dofs left over.
Best wishes,
Henry
Hi,Hvwahl!
Thank you very much!
Yongbin Han
