I am trying to reverse engineer it but I am having problem adding the Facedescriptors. In particular I get an access violation exception with the following code:
I think I’ve found the root of the problem: after the creation of the object FaceDescriptor the private member bcname is null, but from the source code it should be the string “default”. That is causing the exception problem on the assignement of the object.
I tried also to explicitly set the member calling SetBCName but it is still null after the call.
